Well first post on the forum, like to say thank you for adding me. I have been familiar with the MS brand for many years just never anything in hand to play with. Now i am starting my project and there are a lot of features most standalone systems usually offer (I have been tuning since 2004). Currently i have a FC RX7 with a 13b using microsquirt.
List of build
Microsquirt w/custom harness
Tunerstudio licensed w/autotune
GM 3 bar
Gm remote mount TPS
GM Iat
Gm Ect
Mazda factory Cam Crank
innovate LM1 wideband
Gm truck coils, (2 pared for leading and trailing)
no iacv
(will eventually add a 3 port mac valve for pwm boost)
First problem I am having is when looking at tunerstudio and changing the VE or spark tables to more than 100kpa i cant seem to unify the tables? Also is there a way to interpolate the scalars so TS can pick the points between? Really would be nice if i didnt have to manually do this for all the tables, (Ve1, Ve2, AFRT1, AFRT2, Spark1, spark2, etc).
Also i have been reading the MS manual and some guides i found on google, do i put this as a 4cyl like the manual says to do? Also what crank and cam settings should i input?
Im sure there are more questions that will come to me but these are the starting hurtles. Thanks guys
Unifying Tables, and the Newb!
Re: Unifying Tables, and the Newb!
Currently, you'll need to scale all the tables separately.
There are tools to copy rows (highlight the cells, right click on them, and select Copy or Paste) and an interpolate button; these will help scale the tables.
You don't set a two rotor engine as a four cylinder anymore. See rotary engine settings in the MS2/Extra setup manual: http://www.msextra.com/doc/pdf/Megasqui ... Up-3.3.pdf
Thank you Matt for clearing that up. Is there a future request to unify the scalars for up-coming updates?
Also thank you for that manual, going to give it a read threw.
