Injected velocity stacks for DHLA carbs?
Does anyone know if anyone makes this kind of velocity stack that would bolts straight onto DHLA carbs?
I am getting tired of the not-so-forgiving characteristics of carb operation, like loading up in traffic, stalling and not be able to start again, but for this particular car it has to be a rather stealthy install. I am thinking to hide the fuel rail and injectors in the airbox and use the Dell'Ortos as throttle bodies.
Joachim
1974 Jensen-Healey
2014 Ford Fiesta EcoBoost
1974 Jensen-Healey
Re: Injected velocity stacks for DHLA carbs?
I have had a reply from DTAfast (where I found the illustration) that the illustrated air horn will fit DHLAs, they are however pricey (£71 each) and only available in one length - 125mm.
Anyone know of any other sources?
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
Is it ok to spray at a closed butterfly at idle like that?
Can you get generic airhorns and modify them?
Yes, most factory TBIs did that to improve atomization.nathaninwa wrote:Is it ok to spray at a closed butterfly at idle like that?
Of course I could, but that means fabrication... Then it will probably be easier to make it shower (Ducati) type, placing the injector in the centre of the horn just outside the opening. Like this:nathaninwa wrote:Can you get generic airhorns and modify them?
I just nagged eightstack.com again for a DCOE version of their stealth TB. I'm not holding my breath.
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
I got a response from 8stack, they are now part of Borla and a DCOE version of their carb loak-alike throttle body is not on the agenda.
Time to seriously consider shower style...
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
And just when I thought all hope was lost, these guys turn up:
https://www.facebook.com/classicfordmag ... 4433971729
https://www.youtube.com/watch?v=9WD8_4x ... 466yARk8DA
Hidden injectors, hidden TPS, machined from a DCOE casting. Somewhat pricey, ~£750 each - but including Bosch injectors (size unknown). I might just blow next years vacation budget on a pair of those.
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
Northampton motorsport are good guys they mapped my car!
