aem pre turbo wideband setup
Anyone using this setup? How well does it work? I would really like to use cyl to cyl tuning on a turbo set up but im finding it hard to find people who are using this setup that aren't either sponsored by aem or working for them.
Are there any other solutions for accurate afrs pre turbo?
Re: aem pre turbo wideband setup
We typically use a post-turbo wideband and use EGTs for cylinder balancing.
That is my plan b. Since im going to run a single turbo there's no sense in running more than one wide band. I would personally like to be able to at minimum run 1 per bank.
One way to avoid the pressure issue is to make sample chambers where the sensors are in remote chambers and exhaust is brought to them by small tubes. You can see what I mean in that thread: http://www.turbominis.co.uk/forums/inde ... tid=300943.
thats interesting. I may look into that. Id really like to try these aem units. Matt do you know if that controller is compatable with ms3p?racingmini_mtl wrote:One way to avoid the pressure issue is to make sample chambers where the sensors are in remote chambers and exhaust is brought to them by small tubes. You can see what I mean in that thread: http://www.turbominis.co.uk/forums/inde ... tid=300943.
The problem with pre-turbo AFR monitoring is twofold: pressure and temperature. The AEM unit is supposed to compensate for pressure (I put it that way because I have no idea how well it actually works) but you still need to get rid of the heat which may or may not be easy. The sample chambers take care of both issues. And you should note that a too high temperature will kill sensors in addition to giving wrong AFR values.
If you do end up using the AEM unit please do post your findings here. I'd be really interested in hearing independent feedback.
According to what ive read,they use a special stainless bung thats finned to help dissipate heat. Although im not sure how effective it is. if I do try it I'll order only 1 controller and run a o 2 sensor in each bank to test it with another 02 sensor sensor thats knowen to work after the turbo. I'm still a long way away from being able to do any of this just planning right now.
another thing to note here is today's turbos if setup properly don't have all that much back pressure as setups of the past. while there is still pressure they're not nearly as bad as it use to be if you have a properly setup hot side.
when the readings are skewed by pressure does anybody know if it tends to read richer or leaner?
As far as I know, increased pressure will bring AFR readings closer to stoic. That means richer than stoic will read as leaner and leaner than stoic will read as richer.
