Hi, my name is Greg and I'm a new user on here.
I have been debating about Megasquirt for quite some time and decided to jump in. I've also been reading the forums for a while so I figured I should go ahead and register as well so I can contribute when the time comes.
I am swapping a Subaru EZ30 into a Subaru SF5 forester and will be running MS3x. This is not my first engine swap or first fuel injection swap but this is my first Megasquirt build so I'm a little apprehensive. Based on what I've read so far though, I think this will be a good build.
New user from Cincinnati
Re: New user from Cincinnati
Good evening I am in the middle of an ez30d swap in an 02 wrx(in prep for an 818). It was a long three days of tracing wires back and forth to finally figure out I pop the fuse for the coils and injectors. It fired right up using your msq you posted a while back with only changing the req fuel for the 830cc injectors. Hope yours is going well.
