Hi everyone, I delved into the Ms world about 6 or 7 years ago with a v8 Capri which was sold and car projects put behind me.
The bug returned and now I'm building a Haynes Roadster based on a mk2 1.6 mx5. I intend to play with forced induction one day hence wanting an Ms ecu but I don't know which one!
How do I choose? The engine has the stock trigger wheel, iac (integral to the throttle body), sensors, ignition coils, injectors, everything! I'd like to keep as much of that standard as possible but I'm unsure which Ms will work with it all. I don't mind using an edis module but can't remember if that'll fire the Mazdas pair of coils.
I'm also on a tight budget so it'll be a lot I go for but don't want an ms3 if a 2 will work.
Whaddaya think?
Returning user playing catch up with an mx5!
Re: Returning user playing catch up with an mx5!
Sure, they'll work on an MS2. If using the factory Miata harness, also consider a DIYPNP kit - the price is similar, but it's easier to do sequential injection and the assembly takes about half the time.
