Heat Insulated Wire Loom?
What are yall using for wire loom thats heat insulated.
I used this stuff and the black strands melt like nylon rope.
http://www.amazon.com/gp/product/B00M8G ... ge_o03_s00
I cant stand the look of the plastic loom either
I see some cool looking stuff on mcmaster-carr http://www.mcmaster.com/#standard-cable ... ng/=y3bt21
So just wondering if anyone has tired and proven anything.
Thanks,
Mark
Thanks,
Mark
2000 Firebird V6 to LS3 swap.
MS3 Pro
MS3 Pro
Re: Heat Insulated Wire Loom?
I use Raychem dr25 shrink when things are that hot.
I've used this to protect a main harness as it goes within 50mm of a turbocharger exhaust housing:
ThermaShield T6 - 25.4mm x 1.2m - Reflective Heat Shield Sleeve
Installed 2 years ago, working well
http://web.aanet.com.au/arran
I use raychem dr25 and braided nylon.
How about posting links to the shielding.
I didn't post a link because links to eBay will probably be broken in a short while, but this is the product:
http://www.ebay.com.au/itm/ThermaShield ... 0800523824,
This screen grab should be more enduring
Goggled Thermo-tec, Listed at Summit Racing.
http://www.summitracing.com/search/bran ... er=Default
With an E bay listing post the sellers name.
ya i remembered i have some of this stuff so i tried wraping it around my crank sensor wires that go between my headers and my starter so far no issues there .. but i do like the look of those wraps
MS3 Pro
MS3 Pro
