trigger bmw e30m3
trigger bmw e30m3
Im thinking about ms2extra on a bmw s14 engine.
I have read that the original trigger will not work.
original is counting the starters teeth and a refrence tooth. (early bosch motronic)
Why cant I use dual wheel on this one? crank speed the second wheel?
Re: trigger bmw e30m3
How many teeth are on the flywheel? MS3 can do flywheel triggering, but currently only supports 130 or 132 flywheel teeth.
AFAIK 116 teeth. And one separate ref tooth for tdc (2 separate sensors in bellhousing)
but why cant I setup:
toothed wheel
Dual wheel
112 teeth
and every rotation of crank (the one tooth on crank)
toothed wheel
Dual wheel
112 teeth
The code can't handle that number of teeth.
Here's one way you can use MS2 on these motors: https://store.vacmotorsports.com/vac--- ... p1609.aspx
I installed a custom 13cm 60-2 wheel back on crankwheel. used sensor from flywheel on custom mounting.
But should be an easy task to make trigger routine for this engine?
60-2 would use the standard missing-tooth option; no custom wheel decoder is needed.
