Verifying how this should be wired to my cam vr sensor. According to the diagram if im reading this right should be as follows.
12v power to pin 1
Cam signal wire to pin 5
Pin 8 to ecu digital freq
Cam ground wire to pin 11
Pin 12 to ecu sensor ground return
Is that correct? The documents also say "The sensor should be connected in a falling edge configuration
and the measuring equipment should be configured to use the negative going edge." does this matter as i can set the active edge in ms?
motec dmc-c vr conditioner
Re: motec dmc-c vr conditioner
Bump... anyone?
No knowledge on that unit, however I would add - what did it cost?
Jean @ racingmini_mtl markets nifty little "VR Conditioner" chips that are dirt cheap and simple to wire to (if you need some Cam VR signal conditioning).
1983 BMW R100RT Motorbike
Turbocharged - Water/Meth
Sequential Ignition & Fuel
"Perky Sleeper" that excites bike enthusiasts once discovered (or being passed)
Newest project - 1995 BMW K75 is V3 Microsquirt, "Turbocharger - Of Course"
I haven't bought it yet. They are $116.. Jbperf is out of atock and i need it by friday
That looks like the correct wiring.
Thanks matt
