Hi All,
I have an old MS2 (v3.57) that I built some time ago that I finally want to get around to doing something with. I plan to set it up with a 7-pin GM hei module on my existing VR distributor this weekend. I am a little confused by the documentation. I don't understand if/why I need a pull up resistor to supply a 5v reference voltage to the module when the engine starts (not cranking). Given I read Fidle could be used to switch a relay for a thermo fan, I would have thought it would be OK to supply a reference voltage with any other modifications or am I mistaken?
Alternatively, could I just use a relay and take 5v from the TPS, and use Fidle (configured for 12V) to switch the relay on or off an avoid installing a pull up resistor?
Regards Jacob
7-pin HEI 5v reference voltage
Re: 7-pin HEI 5v reference voltage
I'd suggest you update to the current firmware and read the matching manuals.
See "Downloads" and "Manuals" above.
As long as vref on TPS has 5v running you can use that. No pullup required.
Sent from my SCH-I535 using Tapatalk
Megasquirt 2 V3.0 Running Msextra 3.4.2. in a 1989 Camaro RS .48AR/60mm Turbo 3.4L/700R4
Boost control, Fan control, Stepper IAC, Launch/Antilag, Working on the GMDIS, and Methanol injection
Thanks guys - I will try this and report back.
