New here to the site and to MegaSquirt in general. I am getting the MegaSquirt-III Engine Management System w/PCB3.57, no expansion board. I have not received the system yet, so I can't look at it, getting my ducks in a row.
I am going to use a MAF for the system, and the manual says "Solder onto some prototype board. Run jumper wire to JS5 or JS4 (your choice.) Run jumper wire to SPR3 or SPR4 (your choice.)". Does this mean that I have to get a different circuit board to solder the capacitor and resistor to? I would assume that JS and SPR that is referenced are on the MS-3 board and that I would just solder them to the existing board and that the OV-proto just goes to a ground on the board. Is that correct?
Does anyone have some pics of this modification?
Sorry for the Newbe questions, I just don't want to screw this up.
Thx
MS3 MAF Mod
Re: MS3 MAF Mod
http://www.msextra.com/doc/pdf/html/MS3 ... e-1.4.html
that will cover your ecu version, the v3.57 board is a surface mount version of the megasquirt main board it has no proto area like the v3.0 through hole board has, so if you want to add extra circuits it may be easier to use a bit of strip board or similar to accommodate them.
Re: MS3 MAF Mod
Thanks, I decided to just get the MS3X rather than messing around with the unknown.
