Hello
Im more of an old school guy, most of the time. Current set up on my 82 malibu is a blow-thru Edelbrock turbo on a 267v8 running 11lbs of boost.
Bought a MS2 and was going to convert to TPI. Decided to change routes completely.
I plan to swap in a 1uzfe Toyota V8 and run it off the MS2...after some reading Im not sure if that is possible.
Anyways here to learn!
Newbie from MD
Newbie from MD
-Greg...the exhaust guy
-82 Malibu 1uzfe/a340 swap
-10 Yaris, DD
-06 Highlander 3.3AWD
-97 Tercel 1nzfe swap
-96 Tercel turbo 5e
-96 Tercel 4dr
-88 Toyota pickup 22r
-10 Yaris, DD
-96 Tercel turbo 5e
-96 Tercel 4dr
Re: Newbie from MD
Is this the earlier 1UZ or the later VVTi version? And does it have coil on plug or a distributor?
Either one is possible, but the MS2 won't drive VVTi; you'd either leave it disconnected or could upgrade to an MS3 to run that.
Re: Newbie from MD
It will be an early one. Hope to be getting it this weekend.
Id like to convert to COP but I realize that will complicate things
-10 Yaris, DD
-96 Tercel turbo 5e
-96 Tercel 4dr
-10 Yaris, DD
-96 Tercel turbo 5e
-96 Tercel 4dr
