I'm sure there's some information on this somewhere but I've been searching and haven't found it yet...
I purchased an MS1 (B&G PCB 3.0) , soldered it all together and then found out after the fact that MS1 won't control the GM stepper IAC. Thankfully I discovered that I can purchase the MS II daughter board to upgrade to MS2 to control the stepper, but I haven't found any manuals or information regarding the upgrade process.
I assume it's a matter of swapping the daughterboard in place of the MS1 chip and making a few changes. (firmware, jumpers, etc...) If anyone can point me towards a FAQ or manual for the upgrade process I would appreciate it. ...Or do I just use the MS2 manual?
Thanks.
need information regarding Upgrading from MS1 to MS2
Re: need information regarding Upgrading from MS1 to MS2
You're correct. See the notes at this link for details.
http://www.msextra.com/doc/pdf/html/Meg ... 4-102.html
Go through the MS2 build manual to find the 12V feed to the daughtercard for the IAC stepper.
I found it... all of the jumpers have been installed,
Thanks again for the help.
