Hello, i'm Mark Post from the Netherlands. Just finished building a super seven kitcar with a Ford Blacktop Engine.
Engine starts by the the first test. Ecu is programmed default. I want to drive to the dyno to set everything right. But with the default sttings the car isn't drivable. Can anyone support me with a map so i can drive to the dyno.
It is a =Ford Blacktop 2.0 engine with 45mm throttlebodies.
Thanks in advance.
Greetz Mark
New User > Ford Blacktop 2.0 Kitcar Seven
Re: New User > Ford Blacktop 2.0 Kitcar Seven
Hi Mark
Best way is to follow the manual on this.
Every engine is different.
You might check this forum on "Blacktop".
