I am very new and have never setup a megasquirt before. So this is a very basic question my ms1 v3 extra has a map sensor on it as i am running throttle bodys will be using tps only. will this be ok and do i need to disable the map sensor.
my setup will be ford st170 with jenvy throttle bodys using the st170 injectors.
thanks chris
ms1 extra help
Re: ms1 extra help
You would "disable" the MAP sensor by changing the load setting to alpha-N. The MAP sensor is still read and can be used for other functions.
Re: ms1 extra help
so I assume that I still need to install an adapter on each port of the inlet manafold to link to the map sensor on the ecu
thanks chris
thanks chris
