Bought a used V2 3.57
Hi there,
I'm very new to all this and i'm a little lost to be honest. I ended up buying a used megasquirt v2 with the 3.57 board and 3.1.1 firmware. It supposedly was used to run a 2jz, and i want to run a turbo LS. Will i be able to run it? I've found threads of people that have to go through and change the jumpers for distributers and what not and really just want to make sure.
Thanks!
Thanks!
Re: Bought a used V2 3.57
I'd personally go for V3 board. The construction of that makes it easier to repair or modify.
[edit]
Sorry - missed the bit you'd already bought it.
[edit]
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
MS2 V3
Tech Edge O2
London UK.
Yes! You might want someone with experience to set it up correctly or you may choose to do that yourself and learn in the process.Will i be able to run it?
Graduate of EFI University.
Will i have to physically go into the unit and change the jumpers?
Yes.NBraun wrote:Will i have to physically go into the unit and change the jumpers?
Do read the MS2/V3.57 Hardware Manual.
Thanks, Will do!
I'm a little confused. It says to turn one of the resistor pots 7 turns anti clockwise. What is the starting point? There doesn't seem to be a point where it stops.
There are no stops on the pots. There is a little release clip inside that you may hear or feel "click" at each end of the travel, but that is all; the screw will keep turning without limit in either direction. Those are 7-turn pots, so turning seven turns (or more, won't hurt!) ensures it is at the end of its travel, no matter where it started at. That's what you are looking for, full CCW.
Oh, that makes sense. Thank you!
