I agree, you can make the stock injectors spray the required fuel, but to do so you are pushing them to their limits. I would be worried about leaning out at WOT which spells disaster on a boosted engine. The cure for that is a higher rated injector. Not trying to be argumentative, just stating what I have found. If you can point me to more data it would be appreciated.Six_Shooter wrote:Coyote Jack wrote:One of the things you have to do to make the chevy throttle bodies work in a blower application with the hp I have is to replace the injectors with ones that flow more fuel. The reason for this is you don't want to run the injectors at 100% so you need injectors in the 110 lb range and they are not cheap.
Jack
Look up how to make the TBI injector adjustable. ;) It's a free modification.
Jack
