SR20 COP wiring
SR20 COP wiring
I'm half-way through COP converting my 4AGE running MS DIYPNP. However I'm a bit confused when it comes to wiring up my SR20 coil packs.
They have +, - and E clearly marked on them which I would interpret as power, ground and signal. However, when I hooked it up like that it instantly blew a fuse and I haven't tried again.
The colors of the wires in the factory harness seems a bit suspicious too with red going to -. white to + and black to E.
Also, on the factory harness all the black wires going into E were wired together, and so were the white + ones as well, whereas the red - ones had individual wires, leading me to think it's actually the - one being the signal?
Could someone please clarify. Thanks
Re: SR20 COP wiring
I'm not familiar with these particular coils but there are many out there with a secondary ground, given your wire description I'd guess that's what these are. White is +12V, black to engine block or battery ground and red are the negative. You'll need a coil driver to run these, can't connect them directly to logic ignition out. DIY sells the QuadSpark which would work fine.
Graduate of EFI University.
Re: SR20 COP wiring
Did a Google on these, and all the schematics show numbers on the terminals rather than (+) and (-). Very confusing.
Re: SR20 COP wiring
SR20 coils require an external ignition module or BIP373.
Re: SR20 COP wiring
I already have the BIP373s setup and hopefully the right mods to the board as well as the tune.
Hopefully it's only the wiring of the coils remaining.
When you refer to black as ground and red as negative do you mean the red is the "signal" wire and what should be hooked up to the BIP373s?
Cheers
Cheers
Re: SR20 COP wiring
Correct.When you refer to black as ground and red as negative do you mean the red is the "signal" wire and what should be hooked up to the BIP373s?
Re: SR20 COP wiring
I tried that now and now fuses blown this time. Thanks!
However the car isn't starting so I'm guessing I've missed something. I've created a new thread for troubleshooting here if anyone has any ideas:
http://www.msextra.com/forums/viewtopic ... 94&t=64520
