Older turbo 4 cylinder. E85, No A/C, not a daily driver.
I believe the stock computer was sequential injection. I don't care much about that.
I want to use a wideband and have a knock sensor. I believe microsquirt is capable of both with the correct controllers.
looking at this
https://www.diyautotune.com/product/inn ... auge-3795/
and this...
http://www.viatrack.ca/
Are there better options for wideband and knock? i'm not real concerned with gauges, I'll be data logging pretty much anytime I drive the car.
So i'm looking at...
Microsquirt w/ 30" harness - $339
Wideband - $219
knock sensor w/ controller - $65
crank trigger - $70ish
Am I missing anything else? should I run MS2 or 3 over microsquirt and why?
Thanks!
Do I need more than Microsquirt?
Re: Do I need more than Microsquirt?
How are yuo handling spark? Are there any fancy features you might want?
Take a look at the feature chart below; it the uS does everything you want, great! If you run out of pins, or a particular function isn't available, you might need to modify your plans.
If you're doing boost with E85, I'd look more towards the MS3 (MS3X specifically) or the MS3Pro. MS2/Microsquirt is capable of flex fuel but at a basic level.
MS3/MS3X can have a knock module added in.
MS3Pro has a knock module built in.
MS3X/MS3Pro allows for true flex fuel based on table blending. MS2/Microsquirt handles flex fuel as a single fuel and timing adder.
Microsquirt will do what you need but I think you'll be happier with an MS3 based unit.
Personal Vehicle:
Personal Vehicle:
This ^
Support the developers!
Have I said it recently? The price difference between MS3 and the lessor variants is trivial if you are willing to assemble the kit. And, if future trouble-shooting is needed, is the schematic for the Micro even available? Size and weather-proofing are the only distinct advantages that I see for the Micro, and those don't usually matter for a car/truck install.
That's why you buy instead of leasing, even with the lesser variants.billr wrote:The price difference between MS3 and the lessor variants
In the manual ...is the schematic for the Micro even available?
