Do I need more than Microsquirt?
Click here to enter
Contact a Forum Administrator
iniviate
Post by iniviate »
Older turbo 4 cylinder. E85, No A/C, not a daily driver.
I believe the stock computer was sequential injection. I don't care much about that.
I want to use a wideband and have a knock sensor. I believe microsquirt is capable of both with the correct controllers.
looking at this
https://www.diyautotune.com/product/inn ... auge-3795/
and this...
http://www.viatrack.ca/
Are there better options for wideband and knock? i'm not real concerned with gauges, I'll be data logging pretty much anytime I drive the car.
So i'm looking at...
Microsquirt w/ 30" harness - $339
Wideband - $219
knock sensor w/ controller - $65
crank trigger - $70ish
Am I missing anything else? should I run MS2 or 3 over microsquirt and why?
Thanks!
dontz125
Re: Do I need more than Microsquirt?
Post by dontz125 »
How are yuo handling spark? Are there any fancy features you might want?
Take a look at the feature chart below; it the uS does everything you want, great! If you run out of pins, or a particular function isn't available, you might need to modify your plans.
CRSTune
Post by CRSTune »
If you're doing boost with E85, I'd look more towards the MS3 (MS3X specifically) or the MS3Pro. MS2/Microsquirt is capable of flex fuel but at a basic level.
MS3/MS3X can have a knock module added in.
MS3Pro has a knock module built in.
MS3X/MS3Pro allows for true flex fuel based on table blending. MS2/Microsquirt handles flex fuel as a single fuel and timing adder.
Microsquirt will do what you need but I think you'll be happier with an MS3 based unit.
I'm in the VA/DC area! Let me know if I can help you locally! I offer tuning and troubleshooting services.
http://www.msextra.com/forums/viewtopic ... 37&t=64269
Email me directly at CRSTune@gmail.com
Personal Vehicle:
'92 Nissan 240sx, KA24DET, GT2860RS, MS3X, Coil-on-Plug
prof315
Post by prof315 »
This ^
Support the developers!
billr
Post by billr »
Have I said it recently? The price difference between MS3 and the lessor variants is trivial if you are willing to assemble the kit. And, if future trouble-shooting is needed, is the schematic for the Micro even available? Size and weather-proofing are the only distinct advantages that I see for the Micro, and those don't usually matter for a car/truck install.
dontz125
Post by dontz125 »
billr wrote:The price difference between MS3 and the lessor variants
That's why you buy instead of leasing, even with the lesser variants. :D :P
In the manual ... :RTFM:
