Rb25det engine random miss fire
Anyone running Megasquirt 3 3.57 on the rb25 engine and gets a weird dip in rpm, and pulse width and an afr spike? Know of a fix for it? Had it since install. please see at time time 6.116s to 6.313s
Re: Rb25det engine random miss fire
Upgrade to current firmware. Long ago there was an issue that impacted Nissan CASes that sounds exactly like your symptoms.
EDIT: I double checked - the firmware you are using already contains the bugfix.
I was looking into the the noise filter in tuner studio if I use the tach interrupt masking would get rid of that. As you can see above us set to 4
According to the Status reads, the "random" misfire was when you ran into overboost protection mode.
chris_brathwaite wrote:Anyone running Megasquirt 3 3.57 on the rb25 engine and gets a weird dip in rpm, and pulse width and an afr spike? Know of a fix for it? Had it since install. please see at time time 6.116s to 6.313s
Does anything like this happen while cruising also? (Since you said its happened since install).. I'd like to have a look at some other logs if you have more showing any kind of drop please.
Factor9RB25DET wrote:chris_brathwaite wrote:Anyone running Megasquirt 3 3.57 on the rb25 engine and gets a weird dip in rpm, and pulse width and an afr spike? Know of a fix for it? Had it since install. please see at time time 6.116s to 6.313s
it happens while at idle and cruising. where the rpm dips and injector duty cycle drops as well i cant find any more right now. sorry for the late reply.....we may need an email reply to personal email notifying of message on the forum.
