Corrupting Firmware
Click here to enter
Contact a Forum Administrator
jsdevel
Corrupting Firmware
Post by jsdevel »
What are the top ways to corrupt firmware?
Bad cable?
Unstable voltage during flashing?
Loss of power during flashing?
Flashing without wiping the controller clean?
Re: Corrupting Firmware
Post by jsmcortina »
jsdevel wrote:What are the top ways to corrupt firmware?
Bad cable?
Possibly.
Unlikely. The processor needs 5V. The voltage regulator should clean up most instability on the 12V.
100% certainly.
Not sure what you mean here. The reflash process includes a mass erase.
jsdevel
Post by jsdevel »
Thanks James!
Post by Matt Cramer »
Another way to brick an ECU - at least until you reload firmware with the boot jumper; this isn't an unrecoverable bricking - is to set some sort of impossible settings that had not been anticipated in firmware. One example we found a few years ago was that a user had set up a crank trigger where the number of missing teeth was equal to the number of base teeth, creating a zero tooth trigger wheel. Obviously, there's no way to decode this, but it didn't occur to anyone that someone would try it. We've tried to catch every settings conflict, but occasionally somebody gets one through that nobody anticipated.
gboezio
Post by gboezio »
We had a 12V starter cable to come loose and spark on the headers, spark shower lasted for about 30 minutes with a constant relay flickering, huge misfires sequences, tranny gears hunting mostly default 3rd. We welded the header and changed the cable and it's like nothing happened.
jsdevel
Post by jsdevel »
Matt Cramer wrote:Another way to brick an ECU - at least until you reload firmware with the boot jumper; this isn't an unrecoverable bricking - is to set some sort of impossible settings that had not been anticipated in firmware. One example we found a few years ago was that a user had set up a crank trigger where the number of missing teeth was equal to the number of base teeth, creating a zero tooth trigger wheel. Obviously, there's no way to decode this, but it didn't occur to anyone that someone would try it. We've tried to catch every settings conflict, but occasionally somebody gets one through that nobody anticipated.
What is the best way to recover from something like this? Boot jumper and a firmware re-flash? Would one be able to trust their current tune, or would it be better to manually re-create it from scratching using only the required settings?
Boot jumper and a re-flash. Whatever you do, don't load the same problem tune or you'd bring the problem back. Your best bet is to make a new tune starting with the default if you do not have a copy of the tune from before the problem settings got set.
