Ford Cam Sensor Terminals
Click here to enter
Contact a Forum Administrator
Rick Finsta
Post by Rick Finsta »
I'm going to be running a Ford cam synchronizer with the VR sensor and two-pin connector. I can't for the life of me figure out what series terminals cam with the pigtail I've got.
Any ideas?
Here's a link to the connector type:
http://www.bmotorsports.com/shop/produc ... ts_id/1091
dontz125
Re: Ford Cam Sensor Terminals
Post by dontz125 »
That's a Furakawa RFW-series connector. Corsa Technic has them here, as well as spare terminals.
Tell Alex, Don from Canada says hi! 8)
Rick Finsta
Much obliged! I tried a Ford and Chrysler dealership and it seems as though they don't do anything except swap entire harness sections these days... actually I think it's been like that for awhile now.
Rick Finsta
Corsa Technic turns out is local - I had them next day. They weren't exactly correct as this housing doesn't use the little blades but a few seconds on the grinder and they fit perfectly. I'm going to be running VR sensors for the front and rear wheel speeds as well so I'll make good use of these things. The Ford sensors are really quite inexpensive and are very robust.
dontz125
Post by dontz125 »
How very odd - that sure LOOKS like an RFW in the link you put up ... Oh, well - you're all set; glad you got it so fast!
Rick Finsta
I'm guessing the connector is a Chicom ripoff! The OEM Ford unit I've got absolutely has the grooves for those tabs, and this one looks like they were there, but when you try to insert the terminals it's like they don't go all the way through or something. I test fit one of the terminals in the actual Ford connector housing and it fit perfectly. Thanks again for the pointer!
ashford
Post by ashford »
Rick Finsta wrote:Much obliged! I tried a Ford and Chrysler dealership and it seems as though they don't do anything except swap entire harness sections these days... actually I think it's been like that for awhile now.
it seems they are too lazy to pinpoint fix things. here is the ford catalog
https://www.fordparts.com/FileUploads/C ... 202016.pdf
Rick Finsta
I'm not sure I know of a dealership that does anything except replace entire subharnesses these days.
