newbie ecotron,s procal to megasquirt conversion
i have installed an ecotron small engine efi on my 250cc four stroke motorbike , as a i bought the system secondhand (as new, still in the box) ecotrons will not other any back up. I was wondering it is possible to run mircosquirt in the ecotrons ecu. has anyone got any ideas .... Thank you...
Re: newbie ecotron,s procal to megasquirt conversion
The Ecotrons ECU has no known relationship to MegaSquirt, does not use the same firmware, and is not supported here.
Yes i know that there is no connection , but can megasquirt be installed on the ecu ie replace one firmware for another .....if it cannot i will have try and persist with this ecotron .....Thank you
Unless the ecotrons uses the same processor and hardware as the MicroSquirt - in which case I would suggest B&G might become very displeased - the firmware simply will not work. I would wager you can't even LOAD the firmware and have the device turn on.
