MS PNPPRO mx5 90-93 vvt swapped
Click here to enter
Contact a Forum Administrator
BEdrifting
Re: MS PNPPRO mx5 90-93 vvt swapped
Post by BEdrifting »
prof315 wrote:No Your fuel pressure should be 300 Kpa or so.
What might be causing this issue then ? FPR is hooked up the right way according to the megathread. And the feed line and return line are correct aswell.
Sent from my SM-G935F using Tapatalk
BEdrifting
Ok now I'm confused.
Just changed the spark plugs cranked over and when checking if they are wet or not they aren't. In testmode I can fire them all but when cranking there appears to be no fuel. What is causing this issue ?
prof315
Post by prof315 »
Flow test you fuel pump. It sounds to me like it's working electrically but not building pressure
Support the developers!
BEdrifting
prof315 wrote:Flow test you fuel pump. It sounds to me like it's working electrically but not building pressure
Megasquirt doesnt read fuel pressure unless you have an aftermatket pressure sensor the pressure is fine. I got a bit closer to the solution => There was no crank and cam sensor signal when doing the diagnosis thing. So I'm rewiring the tps and both sensors to the additional pins on the megasquirt. I will see if that solves the issues
prof315
Post by prof315 »
I'm well aware of the fact that MS doesn't read fuel pressure unless you have a sensor set up for it. But YOU posted fuel pressure readings so I assumed you had one. The aux upgrade wiring is really for using a newer harness and engine ( 96-00 depending on the swap, 01-05 uses a totally different ECU connector). Get a composite log of the engine cranking and we can see what's up.
BEdrifting
I have a '03 vvt engine in it wich does require wiring changes. And I ment connector 3 on the ecu.
prof315
Post by prof315 »
BEdrifting wrote:
prof315 wrote:
BEdrifting wrote: Megasquirt doesnt read fuel pressure unless you have an aftermatket pressure sensor the pressure is fine. I got a bit closer to the solution => There was no crank and cam sensor signal when doing the diagnosis thing. So I'm rewiring the tps and both sensors to the additional pins on the megasquirt. I will see if that solves the issues
Yeah I understand, Connector 3 is for 97-00 harness swaps.
