Motorcycle Throttle Body size reference?
I Was wondering if there was a site (or a really knowledgeable person) that has all/most of the throttle body sizes available from motorcycles?
I am considering using them on my 2.0 16V project if I can find the right size, but it is difficult to find sizing for them.
Thanks for your help.
I just got 2 sets of 4 CBR929 TB's from West Coast Salvage (UK) through ebay.
40mm capable of 150bhp on the bike, so 2 sets should be fine for a small v8
Have a look at http://tinyurl.com/59kcl for some info, and drop them a mail for specific info ?
Ian (Spag)
http://www.spagweb.com - http://www.v8mini.co.uk - http://www.pievan.co.uk
"The Roughest V8Mini Deathtrap In The World"
How about a "sticky" thread with known specs on motorcycle TB like this:
(Any other info that should be in the list? pictures?)
Donor Make/Model:
Year:
Number of Tb:
Inside Diameter:
Center-Center (left to right from behind):
Overall Length:
Outside Diameter (intake):
Outside Diameter (filter):
Separate casting:
Inj. Flow Rate (45psi/100%):
Rail ID:
Additional Info:
(On my doner tb´s from a Gixxer it would look something like this:)
Donor Make/Model: SUZUKI GSXR600
Year: -02
Number of Tb: 4
Inside Diameter: 38MM
Center-Center (left to right from behind): 80-80-80mm
Overall Length: 83mm
Outside Diameter (intake): 44mm
Outside Diameter (filter): 45mm
Separate casting: YES
Inj. Flow Rate (45psi/100%): 240cc/min (not sure)
Rail ID: 9mm
Additional Info: sec. throttles controlled by ECU.
Donor Make/Model:
Year:
Number of Tb:
Inside Diameter:
Overall Length:
Separate casting:
Rail ID:
Additional Info:
Year: -02
Number of Tb: 4
Rail ID: 9mm
Great idea that a lot of people coud benefit from!Marcus wrote:How about a "sticky" thread with known specs on motorcycle TB like this:
Here is all the info I have gotten:
Throttle Body Diameter Center to Center
Suzuki
GSXR 600 38mm 80mm, 80mm, 80mm
GSXR 750 44mm
2002 GSXR 1000 42mm
GSXR 1000 44mm
GSXR 1300 (busa) 52mm
Kawasaki
ZX6R 636
Z1000
Yamaha
R6
R1
Honda
CBR F4i
CBR600RR
CBR 929
CBR 954
CBR 1000rr
I got most of these from MCNEWS.com.au, these seemd to be motor-side sizes but I cant really say...
kawasaki:
2005 zx6r : EFI with 4 x 38mm oval throttle bodies
2004 zx10 : 43 mm throttle bodies
2002 zx6r : Fuel injection with 38mm throttle bodies
2002 zx12 : Fuel injection with 46mm throttle bodies
yamaha:
2005 r6 : EFI with 40mm throttle bodies
2004 r1 : 45mm throttle bodies; with primary and secondary butterfly valves
2003 r6 : 38mm throttle bodies
honda:
2006 cbr 1000 : PGM-DSFI electronic fuel injection, 4 x 44mm throttle bodies
2004 cbr 1000 : PGM-DSFI electronic fuel injection, 4 x 44mm throttle bodies
2003 cbr 600 : 40mm throttle bodies
suzuki:
2006 gsxr 750 : 40mm
2003 gsxr 1000 : Keihn electronic fuel injection with 42mm throttle bodies
2001 gsxr 600 : 38mm
kawasaki:
yamaha:
honda:
suzuki:
To know the road ahead, ask those coming back. -Chinese Proverb
hey all,
here's another few which are also somewhat larger than 40mm, for the big V8 boys
hayabusa 1999 en 2003 = 46mm 4x
GSXR 1000 oude = 42mm 4x
GSXR 1000 niew = 41>46mm 4x (dual throttle plate)
2002 Aprillia RSV mile = 51mm 2x
Kawasaki ZX12r 2003 = 46mm 4x + vier pintle injectors tot 190pk
Yamaha YZF R1 2004 = 45mm x4 + longnose 4 pintle (dual throttle plate)
ducati s2r 1000 2005 = 45mm x2
ducati monster 620ie 2002 = 45mm x2
all duc twin valve 620 800 en 1000 = 45mm x2
ducati st3 en st4s = 50mm x2
suzuki DL1000 V-strom = 45mm x2 (dual throttle plate)
triumph daytona 955i = 46mm x3
BMW e30 M3 = 46mm x 4
regards Thomas
regards Thomas
marcus started that stick thread, its here
http://www.msefi.com/viewtopic.php?t=6627
Maybe add any extra info you have there?
andrew
andrew
Re: Motorcycle Throttle Body size reference?
SUZUKI
GSR400
GSR400
HONDA
Make/Model: CBR929
Year: -01
Number of Tb: 4
Inside Diameter: 41mm
Center-Center:
Overall Length:
Separate casting: Yes
Injector Make/Model: Keihin,
Flow Rate
Fuel Rail Inside Diameter:
Additional Info: No sec. throttles.
Make/Model: CBR929
Year: -01
Number of Tb: 4
Center-Center:
Overall Length:
Flow Rate
Make/Model: CB400 Revo NC42
Year: -08
Number of Tb: 4
Inside Diameter: 31mm
Center-Center: 70-90-70
Overall Length:
Flow Rate
Year: -08
Number of Tb: 4
Overall Length:
Flow Rate
Found on Internet
MOTOR CYCLE
SUZUKI
Make/Model: GSXR600
Year: -02
Number of Tb: 4
Inside Diameter: 38mm
Injector Make/Model: Keihin KN4, 0J07 AAA A
Flow Rate (45psi/100%): 240cc/min?, 13?
Fuel Rail: Alu casted, Inside diameter 6mm (9mm in the ends)
Make/Model: GSXR750
Year: -98, -99
Number of Tb: 4
Inside Diameter: 46mm
Overall Length: 91mm
Outside Diameter (intake): 54mm
Outside Diameter (filter): 54mm
Make/Model: GSXR1000
Year: -02
Number of Tb: 2
Inside Diameter: 42mm
Overall Length:
Separate casting: No (dual Tb?s)
Flow Rate (45psi/100%): 230cc/min
Year: -03
Number of Tb: 2
Inside Diameter: Tapers from 50 to 42mm
Overall Length: 90mm
Outside Diameter (filter): 53mm
Additional Info: Pic without secondary butterflies and fuel rail.
Make/Model: GSXR1300 (Busa)
Year: pre 2002 ?
Number of Tb: 4
Inside Diameter: 42mm at injector end, tappered from 51mm at air horn end
Outside Diameter (intake): 55mm
Flow Rate (45psi/100%): ?
Fuel Rail Inside Diameter: PA66-G35
Additional Info: no secondary butterfly
KAWASAKI
Make/Model: ZX6R 636 B1
Year: 2003
Number of Tb: 2
Center-Center (left to right from behind): 75-75-75mm
Outside Diameter (intake): 52,6mm
Outside Diameter (filter): 50,8mm
Injector Make/Model: BOSCH 280031V
Flow Rate (45psi/100%): 245cc/min
Additional Info:
Make/Model: Z1000
Year:
Number of Tb:
Inside Diameter:
Overall Length:
Separate casting:
Additional Info:
Make/Model: GPZ1100
Year: 1981-198?
Number of Tb: 4
Inside Diameter: 32mm
Center-Center (left to right from behind): 80-100-80mm
Overall Length:
Outside Diameter (intake): 40mm ("serrated")
Outside Diameter (filter): 40mm ("olived")
Flow Rate (36psi/100%): 180-200cc/min, 2,5?
Additional Info:
YAMAHA
Make/Model: YZF-R6
Year: 2003-2004
Number of Tb: 4
Center-Center (left to right from behind): 72.5-72.5-72.5mm
Overall Length: 95mm
Outside Diameter (intake): 52mm
Outside Diameter (filter): 44mm
Separate casting: Not exactly, but can be cut apart easily (fuel rail)
Injector Make/Model: Keihin ?? # 250031F
Flow Rate (XXpsi/100%): XXXcc/min, 11.7? , 12mH
Make/Model: R1
Year: -04
Number of Tb: 2
Inside Diameter: 43mm
Center-Center (left to right from behind): 78-78-78mm
Overall Length:
Additional Info:
HONDA
Make/Model: CBR F4i
Year:
Number of Tb:
Inside Diameter:
Overall Length:
Separate casting:
Additional Info:
Make/Model: RC51
Year: 2000
Number of Tb: 2, 2 injectors per TB
Inside Diameter: 48mm
Center-Center (left to right from behind): 24mm (TB's are not parallel)
Overall Length: approx 40mm
Outside Diameter (intake): 60mm
Outside Diameter (filter): 70mm (not sure how filter fits)
Separate casting: Yes, TB's are independent, mounted to linkage bracket. Modification needed of fuel pipe and linkages to change spacing.
Injector Make/Model: Huh?/?Huh
Flow Rate (XXpsi/100%): XXXcc/min, approx 11? , ??mH
Fuel Rail: Alu casted, 1 per injector, joined by solid fuel lines
Additional Info: Comes with MAP, fuel regulator, TPS. Has a manual choke mechanism synchronized to both TBs. Not sure how it works - fast idle bleed perhaps?
Make/Model: CBR600RR3
Year:
Number of Tb: 2
Inside Diameter: 37mm
Overall Length:
Separate casting:
Additional Info: Injectors mounted in cylinderhead.
Make/Model: CBR600FSi
Year:
Number of Tb: 2
Inside Diameter: 36mm
Overall Length:
Separate casting: No (dual Tb?)
Additional Info:
Make/Model: CBR 929
Year:
Number of Tb: 4
Inside Diameter: 40mm
Center-Center (left to right from behind): 80mm-80mm-80mm
Overall Length of casting 70mm
Outside Diameter (intake): 49mm
Outside Diameter (filter): - flat flange for airbox
Separate casting: 2 twin body castings
Injector Make/Model: ?? Marked as OK24 B
Flow Rate (45psi/100%): not sure. RUns at 50psi
Additional Info: produces 150bhp at 11,500rpm from 74x54 929cc. 11:3.1 comp ratio, 10 litre airbox.
Make/Model: CBR900 954 Fireblade
Year:
Number of Tb: 2
Overall Length:
Additional Info:
Make/Model: CBR 1100 Blackbird
Year: ??
Number of Tb: 2
Center-Center (left to right from behind): 85-85-85mm
Overall Length:
Flow Rate (43psi/100%): ~335cc/min, 13?
Additional Info:
SNOW-MOBILE
ARCTIC CAT
Make/Model: ZR600 Snowmobile
Year: 1998
Number of Tb: 2
Center-Center (left to right from behind): 134.5
Overall Length: 105mm
Flow Rate (XXpsi/100%): XXXcc/min, 2.9? , 5.8mH
Additional Info: 2-stroke snowmobile, parallel twin 600cc, 105hp
MOTOR CYCLE
SUZUKI
Make/Model: GSXR600
Year: -02
Number of Tb: 4
Make/Model: GSXR750
Year: -98, -99
Number of Tb: 4
Year: -02
Number of Tb: 2
Overall Length:
Year: -03
Number of Tb: 2
Year: pre 2002 ?
Number of Tb: 4
KAWASAKI
Year: 2003
Number of Tb: 2
Additional Info:
Make/Model: Z1000
Year:
Number of Tb:
Inside Diameter:
Overall Length:
Separate casting:
Additional Info:
Make/Model: GPZ1100
Year: 1981-198?
Number of Tb: 4
Overall Length:
Additional Info:
YAMAHA
Make/Model: YZF-R6
Year: 2003-2004
Number of Tb: 4
Make/Model: R1
Year: -04
Number of Tb: 2
Overall Length:
Additional Info:
HONDA
Make/Model: CBR F4i
Year:
Number of Tb:
Inside Diameter:
Overall Length:
Separate casting:
Additional Info:
Make/Model: RC51
Year: 2000
Year:
Number of Tb: 2
Overall Length:
Separate casting:
Year:
Number of Tb: 2
Overall Length:
Additional Info:
Make/Model: CBR 929
Year:
Number of Tb: 4
Year:
Number of Tb: 2
Overall Length:
Additional Info:
Year: ??
Number of Tb: 2
Overall Length:
Additional Info:
SNOW-MOBILE
ARCTIC CAT
Year: 1998
Number of Tb: 2
Ford Zetec Turbo in progress... MSnS-E, EDIS4, LC-1 ect. The engine is running @ 12Psi
andrew
Has this sticky been moved or deleted,as this link gives the message not exists
andrew
I have been looking at the same set up for my car. I have been looking at the earlier style GSXR throttlebodies which do not have that extra butterfly in them, but they are harder to come by. I may go ahead and get the newest style since they are going so cheep. Even though I have a 1.9L I suspect 42mm should be large enough for the street. The jubiride kit is available in either 43 or 45mm......I am not sure what to do about velocity stacks though...Any thoughts??? For filters I plan on looking for some cone shaped, foam motorcycle deals that clamp on over the velocity stacks
i have some experience of MC throttle bodies on cars, as i know two or three people who are using them on various 2.0ltr engines.
The GSXR 42mm bodies are MORE than big enough for a 1.8 ... in fact i know when guy who is running a 2 ltr Zetec on Kawa 600 36mm... and producing over 190 bhp ....
00-03 gsxr-600/750 have the same throttle bodies, same injectors.disc wrote:Found on Internet
MOTOR CYCLE
SUZUKI
Make/Model: GSXR600
Year: -02
Number of Tb: 4
Make/Model: GSXR750
Year: -98, -99
Number of Tb: 4
Year: -02
Number of Tb: 2
Overall Length:
Year: -03
Number of Tb: 2
Year: pre 2002 ?
Number of Tb: 4
KAWASAKI
Year: 2003
Number of Tb: 2
Additional Info:
Make/Model: Z1000
Year:
Number of Tb:
Inside Diameter:
Overall Length:
Separate casting:
Additional Info:
Make/Model: GPZ1100
Year: 1981-198?
Number of Tb: 4
Overall Length:
Additional Info:
YAMAHA
Make/Model: YZF-R6
Year: 2003-2004
Number of Tb: 4
Make/Model: R1
Year: -04
Number of Tb: 2
Overall Length:
Additional Info:
HONDA
Make/Model: CBR F4i
Year:
Number of Tb:
Inside Diameter:
Overall Length:
Separate casting:
Additional Info:
Make/Model: RC51
Year: 2000
Year:
Number of Tb: 2
Overall Length:
Separate casting:
Year:
Number of Tb: 2
Overall Length:
Additional Info:
Make/Model: CBR 929
Year:
Number of Tb: 4
Year:
Number of Tb: 2
Overall Length:
Additional Info:
Year: ??
Number of Tb: 2
Overall Length:
Additional Info:
SNOW-MOBILE
ARCTIC CAT
Year: 1998
Number of Tb: 2
Is there a throttlebody known with
center-center close to 112mm?
Ideally from a twin?
Best, Phulc
Best, Phulc
Is anyone aware of a more modern reference for throttle bodies?
Most of these are older now and therefore rare and/or expensive.
