I apologize for posting this here but I'm not sure where to go. JBPerf hasn't approved my post yet and I was hoping to get this sorted out asap.
I just built a V1.5 JimStim and I was following the "testing and troubleshooting" section listed here:
http://jbperf.com/JimStim/JimStim_v1_5_assembly.html
Under "Testing the tach signal" I hook everything up as stated but instead of getting a blinking IAC led, I've got a solid IAC led. I've triple checked all my solder points, read over everything provided many times, I'm getting 3.3V at pin 1, 3, 13, and 14 with both RPM switches cranked CW. The voltage regulator doesn't get hot under any conditions. I'm just a little lost on where I go from here. Any help would be greatly appreciated!
JimStim V1.5 issues
Re: JimStim V1.5 issues
Just a thought but if you have both rpm pots flat out is the led just blinking too fast for the eye to see the blinks?
Cheers Luke
Cheers Luke
Also check to be sure the transistors don't have any solder bridges.
Actually, it looks like I got my pins mixed up. The Primary Tach text is right under the 5v pins, I need the pins to the left of the text, not above it.
Repinned it and it works. Sorry for the bother guys, but thank you for the suggestions.
