Motorcycle, Snow-Mobile & Car Throttle Specs and Pics
Click here to enter
Contact a Forum Administrator
Postby Marcus » Thu Feb 24, 2005 4:54 am
(Anyone with additional information or corrections can PM me and I´ll put it in this message or you can post as a reply to this message and I´ll put in in the list)
BIG thanks to all who post and PM with additional information. /Marcus
MOTORCYCLE
SUZUKI
Make/Model: GSXR600
Year: -01
Number of Tb:
Inside Diameter: 38mm
Center-Center (left to right from behind):
Overall Length:
Outside Diameter (intake):
Outside Diameter (filter):
Separate casting:
Injector Make/Model:
Flow Rate (45psi/100%):
Fuel Rail Inside Diameter:
Additional Info:
Make/Model: GSXR 600
Year: -02
Number of Tb: 4
Center-Center (left to right from behind): 80-80-80mm
Overall Length: 83mm
Outside Diameter (intake): 44mm
Outside Diameter (filter): 45mm
Separate casting: Yes
Injector Make/Model: Keihin KN4, 0J07 AAA A
Flow Rate (45psi/100%): 240cc/min?, 13Ω
Fuel Rail: Alu casted, Inside diameter 6mm (9mm in the ends)
Additional Info: sec. throttles controlled by ECU.
Make/Model: GSXR 750
Year: -98, -99
Number of Tb: 4
Inside Diameter: 46mm
Overall Length: 91mm
Outside Diameter (intake): 54mm
Outside Diameter (filter): 54mm
Injector Make/Model: Keihin,
Additional Info: No sec. throttles.
Year: 2002
Number of Tb: 4
Inside Diameter: 42mm
Center-Center: 80mm
Overall Length: ???
Outside Diameter (intake): 48mm
Outside Diameter (filter): 52mm
Fuel Rail Inside Diameter: 2.4mm
Make/Model: GSXR750
Year: -06
Number of Tb:
Inside Diameter: 40mm
Overall Length:
Separate casting:
Additional Info:
Make/Model: DL1000 V-Storm
Year: ?
Number of Tb: 2
Inside Diameter: 45mm
Overall Length:
Separate casting:
Additional Info: dual throttle plate
Make/Model: GSXR 1000
Year: -02
Number of Tb: 2
Overall Length:
Separate casting: No (dual Tb´s)
Flow Rate (45psi/100%): 230cc/min
Make/Model: GSXR1000
Year: -03
Number of Tb:
Overall Length:
Separate casting:
Additional Info:
Year: -03
Number of Tb: 4
Inside Diameter: Tapers from 50 to 42mm
Overall Length: 90mm
Outside Diameter (filter): 53mm
Additional Info: Pic without secondary butterflies and fuel rail.
Make/Model: GSXR 1300 (Busa)
Year: 1999-2003
Number of Tb: 4
Overall Length:
Additional Info:
Year: pre 2002 ?
Number of Tb: 4
Inside Diameter: 42mm at injector end, tappered from 51mm at air horn end
Outside Diameter (intake): 55mm
Flow Rate (45psi/100%): ?
Fuel Rail Inside Diameter: PA66-G35
Additional Info: no secondary butterfly
KAWASAKI
Make/Model: ZX6R
Year: -02
Number of Tb:
Overall Length:
Separate casting:
Fuel Rail:
Additional Info:
Make/Model: ZX6R 636 B1
Year: 2003
Number of Tb: 2
Center-Center (left to right from behind): 75-75-75mm
Outside Diameter (intake): 52,6mm
Outside Diameter (filter): 50,8mm
Injector Make/Model: BOSCH 280031V
Flow Rate (45psi/100%): 245cc/min
Additional Info:
Make/Model: ZX6R
Year: -05
Number of Tb: 4
Overall Length:
Separate casting:
Fuel Rail:
Additional Info: Oval TB´s
Make/Model: GPZ750 Turbo
Year:
Number of Tb:
Inside Diameter: 34mm
Overall Length:
Separate casting:
Additional Info:
Make/Model: Z1000
Year:
Number of Tb:
Inside Diameter:
Overall Length:
Separate casting:
Additional Info:
Make/Model: ZX10
Year: -04
Number of Tb:
Inside Diameter: 43mm
Overall Length:
Separate casting:
Fuel Rail:
Additional Info:
Make/Model: GPZ1100
Year: 1981-1982
Number of Tb: 4
Center-Center (left to right from behind): 77-97-77mm
Overall Length:
Outside Diameter (intake): 40mm ("serrated")
Outside Diameter (filter): 40mm ("olived")
Flow Rate (36psi/100%): 180-200cc/min, 2,5Ω
Additional Info: Picture is from a -82
Make/Model: GPZ1100
Year: 1983-1984
Number of Tb: 4
Inside Diameter: 35mm
Overall Length:
Additional Info:
Make/Model: ZX12
Year: 2002-2003
Number of Tb: 4
Overall Length:
Separate casting:
Fuel Rail:
Additional Info: vier pintle injectors tot 190pk ?
YAMAHA
Make/Model: R6
Year: -03
Number of Tb:
Overall Length:
Separate casting:
Fuel Rail:
Additional Info:
Make/Model: YZF-R6
Year: 2003-2004
Number of Tb: 4
Center-Center (left to right from behind): 72.5-72.5-72.5mm
Overall Length: 95mm
Outside Diameter (intake): 52mm
Outside Diameter (filter): 44mm
Separate casting: Not exactly, but can be cut apart easily (fuel rail)
Injector Make/Model: Nipon, # 250031F
Flow Rate (??? psi/100%): ??? cc/min, 11.7Ω , 12mH
Injector Make/Model: Nipon, # 2500322, type: INP250/4
Flow Rate (??? psi/100%): ??? cc/min, ??? Ω
Additional Info:
Make/Model: R6
Year: -03
Number of Tb:
Overall Length:
Separate casting:
Fuel Rail:
Additional Info:
Make/Model: R6
Year: -05
Number of Tb:
Overall Length:
Separate casting:
Fuel Rail:
Additional Info:
Make/Model: YZF R1
Year: -04
Number of Tb: 4
Overall Length:
Separate casting:
Fuel Rail:
Additional Info: Primary and secondary butterfly valves, longnose 4 pintle
Make/Model: R1
Year: -04
Number of Tb: 2
Center-Center (left to right from behind): 78-78-78mm
Overall Length:
Additional Info:
Make/Model: YAMAHA FJ1300
Year: 2003-2006 (US) 2001 up others
Number of Tb: 4
Center-Center (left to right from behind): 77-87.5-77mm
Outside Diameter (filter): 46mm
Injector Make/Model: Keihin ??
Flow Rate:
Other: TB made by mikuni, uses a coolant thermowax type warmup system for high idle, no secondairy throttle. This model has 150 BHP and 99 TQ.
HONDA
Make/Model: CBR F4i
Year:
Number of Tb:
Inside Diameter:
Overall Length:
Separate casting:
Additional Info:
Make/Model: RC51
Year: 2000
Number of Tb: 2, 2 injectors per TB
Inside Diameter: 48mm
Center-Center (left to right from behind): 24mm (TB's are not parallel)
Overall Length: approx 40mm
Outside Diameter (intake): 60mm
Outside Diameter (filter): 70mm (not sure how filter fits)
Separate casting: Yes, independent TB's, mounted to linkage bracket. Modification needed of fuel pipe and linkages to change spacing.
Injector Make/Model: ????/????
Flow Rate (XXpsi/100%): XXXcc/min, approx 11Ω , ??mH
Fuel Rail: Alu casted, 1 per injector, joined by solid fuel lines
Additional Info: Has a manual choke mechanism synchronized to both TBs.
Make/Model: CBR600
Year: -03
Number of Tb:
Overall Length:
Separate casting:
Additional Info:
Make/Model: CBR600RR3
Year:
Number of Tb: 2
Inside Diameter: 37mm
Overall Length:
Separate casting:
Additional Info: Injectors mounted in cylinderhead.
Make/Model: CBR600FSi
Year:
Number of Tb: 2
Inside Diameter: 36mm
Overall Length:
Separate casting: No (dual Tb´)
Additional Info:
Make/Model: CBR 929
Year:
Number of Tb: 4
Center-Center (left to right from behind): 80mm-80mm-80mm
Overall Length of casting 70mm
Outside Diameter (intake): 49mm
Outside Diameter (filter): - flat flange for airbox
Separate casting: 2 twin body castings
Injector Make/Model: ?? Marked as OK24 B
Flow Rate (45psi/100%): not sure. RUns at 50psi
Additional Info: produces 150bhp at 11,500rpm from 74x54 929cc. 11:3.1 comp ratio, 10 litre airbox.
Make/Model: CBR900 954 Fireblade
Year: 2003
Number of Tb: 2
Inside Diameter: Tapers from 45-41mm
Overall Length: 77mm
Outside Diameter (intake): 50mm
Injector Make/Model: Denso 12 226 4490 I suspect the 226 is cc/min, as the bike is good for 150hp... 13.3 ohms
Flow Rate (45psi/100%): ?? (Std fuel pressure on bike is 50psi)
Additional Info: Factory couplers need to be used as inside diameter is offset and not a perfect circle.
Make/Model: CBR1000
Year: -04
Number of Tb: 4
Overall Length:
Separate casting:
Flow Rate (45psi/100%): 240-260cc/min at 43psi (unconfirmed)
Additional Info:
Make/Model: CBR1000
Year: -06
Number of Tb: 4
Inside Diameter: 44mm
Overall Length:
Separate casting:
Additional Info:
Make/Model: CBR 1100 Blackbird
Year: ??
Number of Tb: 2
Center-Center (left to right from behind): 85-85-85mm
Overall Length:
Flow Rate (43psi/100%): ~335cc/min, 13Ω
Additional Info:
APRILLIA
Make/Model: RSV mille
Year: -02
Number of Tb: 2
Inside Diameter: 51mm
Overall Length:
Separate casting:
Additional Info:
DUCATI
Make/Model: MONSTER 620ie
Year: -02
Number of Tb: 2
Overall Length:
Separate casting:
Additional Info:
Make/Model: TWIN VALVE 620, 800-1000
Year: -02
Number of Tb: 2
Overall Length:
Separate casting:
Additional Info:
Make/Model: S2R 1000
Year: -05
Number of Tb: 2
Overall Length:
Separate casting:
Additional Info:
Make/Model: ST3, ST4
Year: -02
Number of Tb: 2
Inside Diameter: 50mm
Overall Length:
Separate casting:
Additional Info:
TRIUMPH
Make/Model: DAYTONA 995i
Year: ?
Number of Tb: 3
Overall Length:
Separate casting:
Additional Info:
SNOW-MOBILE
ARCTIC CAT
Make/Model: ZR600 Snowmobile
Year: 1998
Number of Tb: 2
Center-Center (left to right from behind): 134.5
Overall Length: 105mm
Flow Rate (XXpsi/100%): XXXcc/min, 2.9Ω , 5.8mH
Additional Info: 2-stroke snowmobile, parallel twin 600cc, 105hp
CAR
BMW
Make/Model: M3 e30
Year: ?
Number of Tb: 4
Overall Length:
Separate casting:
Fuel Rail:
Additional Info:
Modified Tb´s
Suzuki GSXR600-02 on Kawasaki GPZ900R -88 (by Marcus)
Suzuki GSXR750 98-99 on Ford 2.3 litre Escort RS2000 (by Exupturbo)
Suzuki GSXR750 98-99 on Yamaha ZXR1000 Turbo (by Exupturbo)
Kawasaki GPZ1100-82 on Ford 1600CVH (by philhoward)
Suzuki GSXR1000 on ST170 Manifold (by Asad)
Honda CB919 on Imp (by Rootes)
Marcus Sundin
GPZ900R A5 Restoration & Modification
www.gpz900r.se
Marcus
Postby Stelz » Fri Feb 25, 2005 2:22 am
Make/Model: SUZUKI GSXR1300 (Busa)
Year: pre 2002 ?
Number of Tb: 4
Fuel Rail ID: PA66-G35
[/img]
Stelz
Postby mikesb » Fri Feb 25, 2005 11:34 am
No additional info to add (I think this is a great idea BTW). I've lots of questions instead :), the answers of which might be useful to keep with the TB info.
I've got TB's from a GSXR600:
There doesn't seem to be anyplace to mount a fuel pressure regulator on the fuel rail. Where is it normally on these things?
The TB appears to have a built in MAP sensor, plumbed to all 4 TB's - is that what it is?
The ECU controls the secondaries, so that big block on the side is a stepper motor of some kind? What's this for, higher air speed for low end torque? Any idea how the ECU controls it? Analog, digital, what engine conditions?
mikesb
Postby Marcus » Fri Feb 25, 2005 11:52 am
Don´t know but anywhere between the filter and the rail will work but I would modify the original rail for fuel in one end and fuel out in the other, blank of the original inlet or use it for ex. pressure guage. This would cool the injectors. I have done it for a friend and here is some pictures of it.
http://www.gpz900r.se/fuel.htm
Yes, it´s the Suzuki MAP.
Not a stepper motor, it´s only a magnet inside with a coil on the outside.
It´s for better throttle response in low revs, Reverse polarity makes the magnet open or close the butterflies and a secondary TPS for feedback so I would call it Analog. IIRC it´s controlled by a tabel like the injectors, can´t find the link about that.
Marcus Sundin
www.gpz900r.se
Marcus
Postby Marcus » Fri Feb 25, 2005 3:39 pm
Found the link on the sec. throttles:
http://venus.13x.com/roadracingworld/is ... 0/gsxr.htm
Marcus Sundin
www.gpz900r.se
Marcus
Postby MegaDave » Fri Feb 25, 2005 5:30 pm
Great Sticky! Thanks guys... i have a couple of additions....
YAMAHA
Make/Model: YAMAHA YZF-R6 Year: 2003-2004
Number of Tb: 4
Injector Make/Model: Keihin ?? # 250031F
Flow Rate (XXpsi/100%): XXXcc/min, 11.7Ω , 12mH
ARCTIC CAT
Make/Model: ARCTIC CAT ZR600 Snowmobile Year: 1998
Number of Tb: 2
Nothing 'squirted yet.......
MegaDave
2000 Honda RC51
Postby mikesb » Mon Feb 28, 2005 7:40 pm
Make/Model: Honda RC51 year: 2000
Center-Center (left to right from behind): 200mm (TB's are not parallel)
Overall Length: approx 400mm
Separate casting: Yes, TB's are independent, mounted to linkage bracket. Modification needed of fuel pipe and linkages to change spacing.
Flow Rate (43psi/100%): 335cc/min, 13Ω , ??mH
Comes with MAP, fuel regulator, TPS.
Has a manual choke mechanism synchronized to both TBs. Not sure how it works - fast idle bleed perhaps? Sure looks like it.
Separated, the TB's can be mounted 200mm on center parallel in their original orientation.
Flip the TB's in 90 degrees so the linkages are touching, they could be 130mm c/c.
<edited using sportbikeryder's info - thanks!>
mikesb
Postby sportbikeryder » Tue Mar 01, 2005 7:47 pm
according to test results listed at http://p090.ezboard.com/fazbiketechfrm19.showMessage?topicID=33.topic
, Honda 1100XX injectors are ~335cc/min @ 43 psi, 100%
sportbikeryder
Postby Marcus » Wed Mar 02, 2005 8:10 am
Thanks Sportbikeryder, I have seen that post before but after much searching never found it again. :D
Marcus Sundin
www.gpz900r.se
Marcus
Postby pandas14 » Thu Mar 03, 2005 11:33 pm
Just took some measurements on my TB's.
03' GSXR 1000:
-Tapers from 50mmID to 42mm ID.
-OD at inlet end is 53mm.
-90mm overall length, +/- 2mm.
Pic without "secondary" butterflies and fuel rail:
Hope that helps.
pandas14
Postby ImpManiac » Thu Mar 17, 2005 6:16 am
I have bought a TB setup from a 2002 Honda Fireblade CBR 954. I plan to fit this onto my 1966 Singer Chamois (Hillman Imp) sprint car - 930cc, OHC, full race tune, ~90bhp plus.
My question is how do these TBs operate at idle? The butterflies appear tightly closed when the throttle cable is slack. Is there a bypass air supply? If so, does it need to be closed when off-idle or at wider throttle openings? That being the case, how can I get a MegaSquirt to control the idle bypass?
I hope someone can point me in the right direction! Thank you in hopeful, eager anticipation.
IM :?
ImpManiac
Postby spag » Thu Mar 17, 2005 6:29 am
I don't know if these will be the same, but on my CBR929 TBs there is an airbleed valve built into each body. They are all operated by a long shaft with 'fingers' the press each valve. There is a thumbwheel adjuster to set idle speed and a vac thing that also operates on it.
Should be fine to leave these open when off idle, but not sure the best way to implement high idle when cold !
Unless you can use a simple solenoid valve to supply vac to the vac thing to increase the idle ??
Ian (Spag)
http://www.spagweb.com - http://www.v8mini.co.uk - http://www.pievan.co.uk
"The Roughest V8Mini Deathtrap In The World"
spag
Postby ImpManiac » Thu Mar 17, 2005 6:50 am
Spag,
You might be onto something there, with that vacuum and solenoid idea. I need to have another look at the TBs. Mine also have the shaft with the fingers on operating an air bleed in each barrel. There is a waxstat for cold start air bleed. Maybe the latter could be retained for cold start with MegaSquirt (given a supply of engine coolant), or a solenoid implemented, suitably mounted. Hmmm. :idea:
I'll keep the forum posted.
IM :D
ImpManiac
Postby spag » Thu Mar 17, 2005 7:09 am
Waxstat... I didn't spot that, is that the thing I think is a vac jobby, with 2 hose fittings on the end ??
Oooo, just taken it to bits, and yep it's a waxstat. :shock:
With all the other vac plumbing I got confused.
Easy for the cold/warm idle thing, but not so good for idle control - sorry :(
Ian (Spag)
spag
Postby ImpManiac » Thu Mar 17, 2005 7:55 am
Spag,
What I meant was remove the waxstat and graft on an idle control actuator from a different vehicle. Somebody somewhere (Imp Club forum, I think) mentioned a Ford Fiesta IAC actuator. I guess that's the stepper motor.
I'd need to check that an IAC control function is available in MegaSquirt, though. I don't think MS can cater for that yet.
The alternative is to set my idle a little high - maybe 1200 rpm - to allow for variations with load, etc. Not ideal, but not my main transport at the moment, so should be okay. Besides, my Webers don't have any automatic idle control! :lol:
IM :D
ImpManiac
2003 Kawasaki 636 TB and injector info
Postby sportbikeryder » Sun Mar 20, 2005 7:49 pm
Did some testing and measuring (not to mention some initial starting, running and tuning with MS :) ) this weekend with the following results:
KAWASAKI
Year: 2003
Outside Diameter (intake): 52.6mm
Outside Diameter (filter): 50.8mm
Injector Make/Model: "BOSCH 280031V"
Flow Rate (45psi/100%): 2 tests completed on two different injectors. #1: 960cc in 235 seconds =~245cc/min #2: 690cc in 166seconds =~249cc/min, therefore, roughly 245cc/min.
sportbikeryder
GSXR 750 bodies
Postby exupturbo » Sat Apr 09, 2005 2:24 pm
I fitted a set of these to my 2.3 litre Escort RS2000 and used Emerald management.
Pics of conversion
Now fitting a set to my 1989 FZR1000 EXUP fitted with IHI turbo.
38mm CV carbs Vs 46mm throttle bodies
re-spaced to suit Yamaha and new billet fuel rail made for supercharged Jag V8 injectors.
End body shortened and adaptor fitted to allow GM TPS to fit
Still need to make the loom for Megasquirt though :oops:
Mark
exupturbo
Postby Devilman » Sun Apr 17, 2005 7:04 pm
exup turbo: Im intruiged as to how your gonna get them TBs to fit your inlet rubbers on the exup, cus the external diameter of them @ inlet side is WAY bigger than your CV carbs.
Im planning on putting MS on my GSXR1100, but a little concerned as to which ones to use, becuase of the limited size of inlet rubbers.
Devilman
Postby exupturbo » Wed Apr 20, 2005 11:51 am
I'm using GSXR750 inlet rubbers which are not much bigger at the cylinder head end than stock exup. I made some adaptors and fitted them to my original inlet manifolds, then matched to the GSXR rubber.
Dodgy pic of inlets and rubbers in place
Bodies with new fuel rail and Jaguar V8 injectors (345cc min at 3 bar)
Pic showing mod to fit GM TPS
Bodies in place
Still plenty to do, but I am winning :)
Mark
exupturbo
Postby russ » Sat May 28, 2005 3:31 pm
[quote="MegaDave"]
YAMAHA
Number of Tb: 4
my r6 tb's have nipon injectors, part no on injectors is 2500322 and manual states type is INP250/4
anyone have a flow rate for this yet? would be much appreciated!
Cheers,
Russ.
russ
Next
Return to General, New users, Purchasing
