Worth It?
Click here to enter
Contact a Forum Administrator
Raymond_B
Worth It?
Post by Raymond_B »
I need to pick up some wire covering and have used the Flexo brand covering before, but then I noticed this https://www.techflex.com/prod_cnn.asp
Looking on line it goes for ~ $2.00-$2.30 a foot which could get a bit pricey, but if it really protects against RFI seems like it would be worth it. I was thinking of using it to wrap my crank and cam sensor wiring, coil wiring and then the MS harnesses inside the vehicle.
http://www.buildpics.org/
Drew442
Re: Worth It?
Post by Drew442 »
I was thinking of using this
10M 8Sizes Insulation Braided Sleeving 4/6/8/10/12/15/20/25mm Tight PET Expandable Cable Sleeves Wire Gland Cables protection
http://s.aliexpress.com/Vnia2qE3
Sent from my MI 5 using Tapatalk
Raymond_B
Re: Worth It?
Post by Raymond_B »
Drew442 wrote:I was thinking of using this
Looks good, but I do not see RFI protection in the specs, did I miss it?
LAV1000
Re: Worth It?
Post by LAV1000 »
Raymond_B wrote:I need to pick up some wire covering and have used the Flexo brand covering before, but then I noticed this https://www.techflex.com/prod_cnn.asp
I don't see any figures on how much it protects against RFI.
Raymond_B
Re: Worth It?
Post by Raymond_B »
Yeah, I poked around on their website and they give all kinds of info, except for that... If the wiring loom did protect from RFI would it not need to be grounded?
LAV1000
Re: Worth It?
Post by LAV1000 »
Lets put it this way.
If I know there is a change that RFI messes up something I use screened wire and not this plastic sleeve whit some carbon in it.
I know there are plastic foils which do work this way, but they are used on data cables.
These are mostly used in a total different in environment.
On the other hand they put a nice list whit it for resistance to chemicals.
If I want to use it I'd select it on the chemical resistance,not the carbon RFI issue.
