Open collector or built-in pull-up?
Click here to enter
Contact a Forum Administrator
gearheads
Post by gearheads »
Hi, this is my first post and I hope someone can help me out. I´m finishing the assembly of my MS2 V3.0 board and I need to add a cam sensor input as my Ford Focus 2.0 16V Duratec HE engine has COPs but I can´t figure out whether the gear tooth sensor is open collector or has a built-in pull-up. The meter shows an open circuit between all three pins. The part number is 6M8G-12K073-BA. I also need to find out what each pin is supposed to be and how to test the sensor. Thank you guys.
dontz125
Re: Open collector or built-in pull-up?
Post by dontz125 »
Assuming you were using an ohmmeter, open circuit between all three pins indicates an open-collector.
The OEM wiring schematic should indicate which pin is which.
gearheads
Post by gearheads »
I did use an ohmmeter so I have an open-collector cam sensor. Good, I can complete the board soldering. What I can´t find anywhere is the wiring schematic or the sensor pinout. Thank you.
