Can i use my four post exciter from the inside of my stock dizzy to trigger the RPM signal for when i upgrading to coil on plug (LS1) ignition? (example picture attached
im deleting the cap/rotor/spark plugs and cutting the the shaft down so i can cover it all with a thin "decorative" cap.
i dont know want kind of signal is sent from the stock cam sensor but i was thinking of getting a new aftermarked VR senor for a fresh clean signal (single rpm input) to the megasquirt. i just want to know if i can get away using the four post or the one post higher on the shaft like in the other picture for the input signal running 4 coil on plug igniters (two outputs). i could get a crank 32-1 but i only want to go that rout if the stock cam rout wont work
Megasquirt 2 3.0 DYI kit
'86 Toyota 4Runner 22rte ~200hp
) VR/Trigger wheel/coilonplug question
Re: VR/Trigger wheel/coilonplug question
If the dizzy can have both the 1-tooth wheel and 4-tooth wheel in it, as well as separate sensors for each, then COP can probably work. However, the timing accuracy with just a 4-tooth wheel in the dizzy is so crude it seems hardly worth the expense and bother to go to COP. Just stick with single-coil using the 4-tooth wheel for "basic trigger".
ive had the coils sitting around for some time now and this build is so out of control at this point the ignition is the only thing not custom. so figured i just upgraded to MS2 and now i have the capability to run COP and i have the coils so might as well. plus it be pretty sweet.
and this thread is actual already out of date. thought might as well do the better more accurate trigger wheel. decided to just do a generic 32/1 crank instead. 6.5' OD and 5.25" ID and ill just attach it to the crank pully.
Go for 36-1 (10 deg per tooth), not 32-1 (11.25 deg per tooth.)
dang, already ordered it. haha. i didnt see a 36/1 offered from the company i bought from though.
