What would you do with this?
Click here to enter
Contact a Forum Administrator
Raymond_B
Post by Raymond_B »
Found it at my neighbor's garage sale. Ended up getting it for free, so it's a signal generator? Anything useful for a Megasquirt? Simulate something?
http://www.buildpics.org/
LAV1000
Re: What would you do with this?
Post by LAV1000 »
It is old and was expensive then:
http://www.radiomuseum.org/r/hewlett_pa ... _204d.html
It only make's sinusodial wave's of max 5V from 5Hz to 1.2MHz.
So no missing tooth or pwm signal. :(
R100RT
Post by R100RT »
Could be part of that "Flux Capacitor" project many wish to get on with 8)
1983 BMW R100RT Motorbike
Turbocharged - Water/Meth
Sequential Ignition & Fuel
"Perky Sleeper" that excites bike enthusiasts once discovered (or being passed)
Newest project - 1995 BMW K75 is V3 Microsquirt, "Turbocharger - Of Course"
DaveEFI
Post by DaveEFI »
Thing is to make it much use as a test instrument for MS, you'd have to match the signal exactly to the one from a sensor. Making it not much more use than a Stim - and a lot less than a JimStim which can generate different tooth wheel signals.
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
ashford
Post by ashford »
i use a signal generator to setup the vr pots. dc voltage offset is a plus if it has it
It could be used to simulate a basic distributor trigger or various frequency based sensors (flex fuel, MAFs, speed sensors, etc).
