Found it at my neighbor's garage sale. Ended up getting it for free, so it's a signal generator? Anything useful for a Megasquirt? Simulate something?
What would you do with this?
http://www.buildpics.org/
Re: What would you do with this?
It is old and was expensive then:
http://www.radiomuseum.org/r/hewlett_pa ... _204d.html
It only make's sinusodial wave's of max 5V from 5Hz to 1.2MHz.
So no missing tooth or pwm signal.
Could be part of that "Flux Capacitor" project many wish to get on with
1983 BMW R100RT Motorbike
Turbocharged - Water/Meth
Sequential Ignition & Fuel
"Perky Sleeper" that excites bike enthusiasts once discovered (or being passed)
Newest project - 1995 BMW K75 is V3 Microsquirt, "Turbocharger - Of Course"
Thing is to make it much use as a test instrument for MS, you'd have to match the signal exactly to the one from a sensor. Making it not much more use than a Stim - and a lot less than a JimStim which can generate different tooth wheel signals.
i use a signal generator to setup the vr pots. dc voltage offset is a plus if it has it
It could be used to simulate a basic distributor trigger or various frequency based sensors (flex fuel, MAFs, speed sensors, etc).
