msq for triumph parallel twin
Click here to enter
Contact a Forum Administrator
5pointsvintage
Post by 5pointsvintage »
hello, thanks for the add. I have turbocharged a 1958 Triumph twin. The microsquirt is a fuel only system that runs with vr1- as tach signal. from a pazon digital ignition. would like information on the basic msq setting that should be used? MSQ as is.
LAV1000
Re: msq for triumph parallel twin
Post by LAV1000 »
Hello,
Check the manuals top left, Quick links:....
If your running a turbo the max map limit needs a bit more ?
You can choose a 16x16 fuel map instead of 12x12.
When using a low Z injector pwm style Thershold time needs to be less.
This are the things I noticed, check it for yourself and verify whit the manuals.
5pointsvintage
Thank you for the reply. I am new to EFI and the learning curve is huge. Will let you know what come of the changes after we test it. need to studie each one of the sections before moving foward.
thanks again for the tips,
5 Points
Raymond_B
Post by Raymond_B »
You're also required to post pictures of that bike:)
http://www.buildpics.org/
5pointsvintage
here is a link to the bike @Bonneville Speed Week 2017 just 5 days ago.
https://scontent.fapa1-2.fna.fbcdn.net/ ... e=5A165779
LAV1000
Post by LAV1000 »
Nice bike, like it.
Something to read, about ignition control on triumph:
http://www.msextra.com/forums/viewtopic ... it=triumph
