Normal aspired engines don't go up to 163 kPa map value.balzonya wrote:what did you mean by this?LAV1000 wrote:
Did take a look at the msq file and noticed some things.
Your runnig a turbo 163 kPA ?
The 163 kPa was the vertical axle on fuel and ignition table.
Did take a look again and on all your tables, Ve, Ignition, Afr, the vertical axle (value) is different.
Was this a used unit ?
I don't think this are default settings.
Did you change the pwm settings ?
Really try to read and use the manual, you don't have to read it completely.
Just read the part on the settings your working on/with.
