1st off, new to the site so Hi all.
I am building a focus st170 turbo running on MS1 V3 with EDIS. (not using the vvt, it is blanked off)
I am not getting a spark, the fuel pump primes and im 99% sure its injecting. Ive checked and checked my wiring and all seems to be in place correctly.
So does anyone have any idea why i have no spark?
I did do a cvh turbo about 8 years and and im sure i had the same problem then but cant be 100% sure.
Any help would be greatly appreciated.
Thanks Rob.
Newbie, MS1 No spark ? please help
Re: Newbie, MS1 No spark ? please help
if you are not getting spark its the edis you need to look at, that should create sparks even if the ecu is not connected
Sorted now thanks.
