Gday mates.
I'm Michael. I'm from Australia.
I am currently fitting ms2 with edis4 to a sc12 blow through intercooled mini..
I am not going to bore you with my trials and tribulations. Because man I have had millions so far... Anyway I digress
My edis module is not firing my coils. Even with the 2 wires to the ms disconnected.
I have power, good earth, good continuity to the coil pack....
I have tested the pins at the edis4 and I have a what appears to be a short between pin 9 (earth) and pin 10. I would expect this briefly as the coil would be "earth switched" but it stays on.
I'm in Australia and just grabbing another module and trying it is a little harder.
Could anyone offer me any suggestions?.
Even if I could find an actual schematic of the edis4 module I could find out why the pin 10 has a seemingly permanent ground...
I may be missing something obvious..
Thanks in advance for any Imput. I really do need it,
Edis4 module problem
