Hi all,
I'm out of ideas as to why I'm getting random SecL resets, and I'd appreciate a fresh set of eyes.
Is there anything in the datalog that looks out of place?
Thanks in advance.
Random SecL resets (datalog MSQ attached)
Re: Random SecL resets (datalog MSQ attached)
Which MS variant is this, and where is it grounded?
MS2. Grounded at the intake manifold.Matt Cramer wrote:Which MS variant is this, and where is it grounded?
Try grounding to the battery.
Grounding my ECU & O2 sensor directly at the battery hasn't helped my reset issue. I believe I can rule out grounding for the issues I've been having at this point. Ran new 2 AWG wire from battery to block, 4 AWG from battery to frame, new 2 AWG power cable from battery to starter, dedicated 10 AWG ground lines from MS2 to battery and O2 sensor to battery. Used hydraulic lug crimpers. Terminals are all tight. ECU & O2 sensor power feeds and grounds are directly at the battery terminals.
Here's a new thread based on my new theory: Invalid Closed Loop Idle Settings. Any help is appreciated.
