megasquirt2 firmware for wasted spark COP
Click here to enter
Contact a Forum Administrator
blink977
Post by blink977 »
Hi all!
I'm new to megasquirt, and currently I'm working on megasquirt2 BMW M60 engine project
the board is assembled and wired, I have an engine rmp signal, injectors and fuel pump are working also.
The problem is in spark, I have it but only from D14 (top of R26). I think the problem is in firmware, because I can't find settings in Tuner studio MS, to enable other spark outputs.
Anyone can help with correct firmware? My current is release 3.4.2 for MS2 daughtercard. The board itself is V3
grom_e30
Re: megasquirt2 firmware for wasted spark COP
Post by grom_e30 »
by setting it to wasted spark the other outputs are automatically enabled. the firing sequence is hard coded it always fires the outputs a,b,c,d. did you build the additional spark outputs on the board/
blink977
Post by blink977 »
spark A comes from D14
spark B comes from D15
spark C comes from D15
spark D comes from bottom of R1, with R1 removed
does anything needs to be built? I have 4 VB921s wired to this output
I have spark from D14, I just don't have additional 3 outputs
grom_e30
Post by grom_e30 »
no spark in test mode or just cranking? can you post the tune file
blink977
Post by blink977 »
dude, I have a spark on spark plug on cylinders 1-5 from c top of r26. The question was how to enable other spark outputs.
my enigne firinng order is 1-5-4-8-6-3-7-2, so, I have cylinders 1-5 connected to spark A, cylinders 4 and 8 connected to spark B, cylinders 6 and 3 connected to spark C, cylinders 7 and 2 connected to spark D. Is that right?
injectors are fired by 4 injectors at one time, 1,5,4,8 one bank, 6,3,7,2 second bank
my tune file is absolutely stock and default yet, so there is no reason to post it here. Once I will enable spark outputs, I will correct dwell, and other settings
grom_e30
Post by grom_e30 »
1-5-4-8-6-3-7-2
A B C D A B C D
1+6=A 5+3=B 4+7=c 8+2=d
if you set your number of coils to wasted spark it will enable outputs a-d that's assuming your msq is set up correctly.
blink977
Post by blink977 »
oh, I have to rewire it
thank you
blink977
Post by blink977 »
re wired ignition coils today, tried to start but got starter kickback
Anyone knows what ignition setting should be used for the first time, on BMW M60 V8?
billr
Post by billr »
Post the MSQ and confirm spark timing with a (simple) strobe light.
blink977
Post by blink977 »
unfortunately I don't have strobe light :(
racingmini_mtl
Post by racingmini_mtl »
Buy/borrow/rent one. No one can help you until you do because that's the only way to know the actual timing.
grom_e30
Post by grom_e30 »
the m60 uses individual coils per cylinder? they are dumb coils if i remember correctly so need a ignition transistor per coil, how exactly are you driving the coils with 8x bip373 ignition transistors? pictures of the ignition outputs may help. also can you fire all the coils in test mode?
blink977
Post by blink977 »
Yes M60 uses a dumb coils. I'm running 4 STP8005 transistors from stock BMW DME, one transistor drives 2 coils at one time in wasted spark mode.
Update: After test mode I realized that I had error wiring in ignition coils, spark A comes from R26 as I expected, but spark B came from R29 and not R27. After re wiring there were no kickbacks, engine catches up but won't start. I also don't have spark from bottom of R1, does it needs to be enabled separately?
I played with cranking pulse also, but no luck, I can smell gasoline, and spark plugs are wet. Looks like I have too much fuel.
the engine is 4.4 liter, and has supercharger installed, I'm running volvo orange injectors, 320cc at 3.5bar of fuel pressure.
can someone advice startup settings?
grom_e30
Post by grom_e30 »
if your msq is set correctly setting to wasted spark will enable outputs a-d. did you omit r1? and i take it spark D did not work in test mode either?
you should have spark d connected to js11, i believebottom of r1 is for ms1
blink977
Post by blink977 »
yes, my spark D is connected to bottom of R1, with R1 removed. this is for V3.0 board
grom_e30
Post by grom_e30 »
it should go to js11
blink977
Post by blink977 »
I'm not sure why, but when I connected spark D to JS11, it worked. by manual, it should have been working from the bottom of R1, but it did not... no matter..
I still have kickbacks, and engine throws from exhaust, sometimes it slows down during cranking like something holding it, I'm sure it is timing...
checked ignition coils wiring again in test mode, engine firing order is 1-5-4-8-6-3-7-2, so spark A is 1 and 6, spark B is 5 and 3, spark C is 4 and 7, spark D is 8 and 2.
there is to much fuel sitting in cylinders, because when I tested spark, it shot out from muffler, burning unburned fuel.
I don't have any idea what is wrong :( I could not find strobe light, no one have it in my city, in order to use it, I have to buy it on ebay and wait for two weeks or so :(
grom_e30
Post by grom_e30 »
is your tooth #1 angle correct?
blink977
Post by blink977 »
grom_e30 wrote:is your tooth #1 angle correct?
this is the main question :( I don't know how many degrees it should be
it worked best with 60 degrees so far, and 20 degrees cranking advance
the engine is M62B44 non vanos, with rear crank sensor
I'm also having problem with msq reset when cranking, I thought it was ground cable and added additional ground to engine, and it became even worse.
when cranking, Tuner studio shows "cranking" and "rmp sync" with green color, then it becomes red for a sec, then comes green again. tooth logger showed two high green lines in place of missing teeth, after adjusting R56 it became normal, but no luck still :(
grom_e30
Post by grom_e30 »
are you seeing sync loss or resets as they are different things. post the logs and tune
