megasquirt2 firmware for wasted spark COP
Click here to enter
Contact a Forum Administrator
blink977
Re: megasquirt2 firmware for wasted spark COP
Post by blink977 »
grom_e30 wrote:are you seeing sync loss or resets as they are different things. post the logs and tune
I'm seeing both of them
toothed wheel log attached
2017-10-12_17.32.49.csv
(47.67 KiB) Downloaded 26 times
grom_e30
Post by grom_e30 »
yeah doesn't look quite rite how does it look with out the plugs in?
blink977
Post by blink977 »
grom_e30 wrote:yeah doesn't look quite rite how does it look with out the plugs in?
what do you mean?
grom_e30
Post by grom_e30 »
does the tooth log look better with the spark plugs removed that way the starter will not be fighting compression
blink977
Post by blink977 »
grom_e30 wrote:does the tooth log look better with the spark plugs removed that way the starter will not be fighting compression
I was thinking about this, but I was too lazy to remove spark plugs today :(
will try this tomorrow
If it will be better, what does this mean?
grom_e30
Post by grom_e30 »
incorrect tooth #1 you need the strobe light to confirm this really, or possibly incorrectly adjusted vr input circuit. can you see the trigger wheel or is it on the flywheel on that engine?
blink977
Post by blink977 »
grom_e30 wrote:incorrect tooth #1 you need the strobe light to confirm this really, or possibly incorrectly adjusted vr input circuit. can you see the trigger wheel or is it on the flywheel on that engine?
it is on the flywheel. and crakshaft sensor itself is on the bottom of the gearbox. engine ran fine before I removed stock wiring and DME
grom_e30
Post by grom_e30 »
if the tooth # 1 is wrong the ecu will be firing the spark at the wrong time though.
blink977
Post by blink977 »
grom_e30 wrote:if the tooth # 1 is wrong the ecu will be firing the spark at the wrong time though.
is there any way to find this out without strobe light?
jsdevel
Post by jsdevel »
You should really be testing on a stim. You'll dramatically lower your feedback loop. I wouldn't test anything on the car until I've verified it on a stim. Tried testing on the car first before I bought a stim and wasted loads of time.
Once you have it working on a stim, thoroughly read the setting up manual (not the hardware manual). Testing with a strobe is covered there.
Sent from my Nexus 6P using Tapatalk
jsdevel
Post by jsdevel »
Also, when using a strobe, I found it helpful to have the ignition advance gauge viewable in TunerStudio. You can set cranking advance to 0 degrees or adjust your strobe if you can.
blink977
Post by blink977 »
jsdevel wrote:You should really be testing on a stim. You'll dramatically lower your feedback loop. I wouldn't test anything on the car until I've verified it on a stim. Tried testing on the car first before I bought a stim and wasted loads of time.
I have bought it already, will have it in few days.
Also, gonna build strobe light myself. found a lot of schematics around
jsdevel
Post by jsdevel »
Here's what I use https://m.harborfreight.com/timing-ligh ... 20provided. Has an adjustable knob for advance.
blink977
Post by blink977 »
fired it up today... I removed all spark plugs and adjusted VR conditioner for correct crank sensor signal
After that, engine fired right up.
what should I do next? I mean, which tables and setting must be adjusted?
jsdevel
Post by jsdevel »
Probably AFR table, then dial in idle. Then tune analyze live once you have it warmed up.
