TPS shows WOT during engine cranking/startup
Click here to enter
Contact a Forum Administrator
adam12
Post by adam12 »
I have a Ford TPS and it is set for 0 and WOT but when I try to start the engine the TPS shows 100% just while the starter is engaged then it goes back to normal. I have to turn off the overboost protection or it will not start at all. Any suggestions as to why it is doing this? I have the same ground and 5v supply for the MAP and TPS sensors but each has their own signal back to the ECU. Thank you in advance.
adam12
Re: TPS shows WOT during engine cranking/startup
Post by adam12 »
Any suggestions would be greatly appreciated. Is there a setting in tunerstudio that could help or is it some type of ground issue or other wiring mishap?
grom_e30
Post by grom_e30 »
sounds like a grounding issue
