RPM dot jitter. Is that normal?
Click here to enter
Contact a Forum Administrator
maych87
Post by maych87 »
My rpm dot is super jittery. I am trying to set up my engine states but it is difficult with the amount of oscillation I get when I data log the rpm dot.
1. Is that normal to have that jitter?
2. Is there a way in any of the settings to reduce the jitter?
Any help would be greatly appreciated.
Sent from my iPhone using Tapatalk Pro
jsdevel
Re: RPM dot jitter. Is that normal?
Post by jsdevel »
General settings I believe. You can adjust smoothing.
whittlebeast
Post by whittlebeast »
:msq:
maych87
Post by maych87 »
msq and datalog are attached
also there is no smoothing that i can see for rpm dot under general settings.
200 wue2017-11-20_12.07.26.msq
msq
(286.49 KiB) Downloaded 35 times
2017-10-30_15.06.38.msl
datalog
(722.68 KiB) Downloaded 49 times
The RPMdot readings look pretty real to me. Looks like there was a misfire when you gave it more gas at around 73 seconds, possibly a bad spot on the VE table there.
maych87
Post by maych87 »
jsdevel wrote:General settings I believe. You can adjust smoothing.
I went back and looked under general settings and adjusted the smoothing on the rpm. I’m not sure how I missed that before. After adjusting it everything works great thanks.
