My rpm dot is super jittery. I am trying to set up my engine states but it is difficult with the amount of oscillation I get when I data log the rpm dot.
1. Is that normal to have that jitter?
2. Is there a way in any of the settings to reduce the jitter?
Any help would be greatly appreciated.
Sent from my iPhone using Tapatalk Pro
RPM dot jitter. Is that normal?
Re: RPM dot jitter. Is that normal?
General settings I believe. You can adjust smoothing.
msq and datalog are attached
also there is no smoothing that i can see for rpm dot under general settings.
- Attachments
- 200 wue2017-11-20_12.07.26.msq
- msq
- (286.49 KiB) Downloaded 34 times
- 2017-10-30_15.06.38.msl
- datalog
- (722.68 KiB) Downloaded 47 times
The RPMdot readings look pretty real to me. Looks like there was a misfire when you gave it more gas at around 73 seconds, possibly a bad spot on the VE table there.
I went back and looked under general settings and adjusted the smoothing on the rpm. I’m not sure how I missed that before. After adjusting it everything works great thanks.jsdevel wrote:General settings I believe. You can adjust smoothing.
