TPS values
TPS values
Hi All
Trying to configure the ITB lode settings.on Moto Guzzi 1200 8v
Can’t get the TPS value across the RPM range, from the manufacturers.
If anyone our there installed a Microsquirt on a Moto Guzzi EFI
and have these values for me, It will be greatly appreciated.
Griso
Griso
Re: TPS values
This depends highly on your setup. If you have a large datalog and are confident you've correctly calibrated you TPS and adjusted your idle, you can send it to me via private message if you have trouble extracting the curve. I suggest watching https://www.youtube.com/watch?v=_GDZxUVTplk and trying it yourself first, though.
My project: Link
Re: TPS values
Thanks Dennis
The video was very helpfull, my only question is, can i do the data logging by just revving up the engine.
Or do i have to do it on a dyno
Griso
Griso
Re: TPS values
I doubt this will work without load on the engine. Also, note that you're not looking for 90kpa, but for 90%baro.
My project: Link
Re: TPS values
Hi Dennis
I apologise for taking so long to get back to you, I needed to fabricate a mount to hold the laptop on the motorbike so i can do a data log
I’m not getting 90% on the Histogram / Table Generator. Data Loge Please find data loge attached
- Attachments
- Dataloge7.msl
- (570.18 KiB) Downloaded 26 times
Re: TPS values
Calibrate your TPS and verify it's working correctly afterwards. According to the log, it currently does not.
My project: Link
Re: TPS values
My problem is i can’t calibrate because I’m not getting the same table in Histogram as in the vedeo.
I have the X Axis = RPM Y = TPS and Z = MAP. What do i need enter in Z Axis Delta.
Are you abel to get a table showing 90’s from my log?
Re: TPS values
Your TPS is not calibrated correctly or malfunctioning. You have to fix this first!
My project: Link
