GM LS Gen 1V Cam Sensor wiring problem
Click here to enter
Contact a Forum Administrator
xrtim
Post by xrtim »
Hi
I'm looking for so help on wiring up the Gen 1V cam sensor to a MS3 Ultimate that I have just purchased, I understand that the sensor needs a 5v supply which i can connect to one of the VREF 5V + outputs from the ECU and then connect the CMK + and a sensor return. The problem I have is with the connector pin designation, I can't seem to find any information on the connector I have, looking into the 3 pin connector with the locking tab up I have right to left A terminal red wire, B in the middle pink with black wire and C brown and white wire. Can you tell me which wire goes to where, or in idiot speak how I can test sensor to find out. Never done this before so bear with me and the engine hasn't been run before just finished building it
Regards Tim
