would you recommend this type of O2 sensor bung extender ?
will it affect sensor accuracy, response time, other drawback ?
I want to protect my O2 snesor from heat, but I can't use straight extender because there is not enough room between exhaust and car body..
any thoughts appreciated.
O2 sensor bung spacer
- Attachments
- HTB1a85dcMoSMeJjSspaq6zMOFXaM.jpg (114.02 KiB) Viewed 342 times
1978 vw golf gti 16v itb cop full sequential MS2
1992 vw corrado 16v moonlight blue MS2
Re: O2 sensor bung spacer
Probably nano seconds worth of difference. The exhaust gas will swirl around in there just fine. Straight is better in that it's fewer parts to purchase. In your case you don't really have a choice.
used this type on my s3 when having sensor overheat problems works fine no problems now
