Question about low imp injectors, PWM, and flyback board..
I was just wondering if I should use the flyback board for my setup. I will be using 4 Delphi low imp 780cc injectors on a 4cyl boosted motor. With that large of injector, i really need to keep the low imp "faster reacting" function of the injector, so i dont want to run resistors. I guess my question is that by using the flyback board, does MT/MS treat these as high imp by not even using the PWM feature(just flyback board), or do you still use PWM along with the flyback board? I know quite a few people just use PWM only with low-Z injectors without issue..I'm just thinking of long term durabiltiy/reliability of the flyback circuit..
This is right out of the megamanual.
People running a number of very low impedance injectors have reported problems with the flyback circuit failing. Typically, this will happen with 4 or more low-impedance injectors, such as the Holley 85 lb/hr TBI injectors. This can be avoided by using resistors in series with the injectors, and disabling the pulse width modulation (PWM). However, a more elegant solution that continues to use PWM is the Flyback Board.
Brad
Brad
Bringing this back for a quick question:
I'm in the exact same situation, 75lb/hr injectors (low impedance) but with a resistor pack. To disbale PWM, I'm guessing you would simply set PWM current limit to to 100%, and the Time Threshold to 25.4, correct?
Darin Chalifoux
97 Dodge Ram 1500 4x4 360cid
93 Colt GL
92 Talon TSI AWD Automatic
93 Colt GL
