I am also interested in using gaseous injection (but with LPG). I understand that the system is much less complicated then injecting LPG in it's compressed state, but I'm still finding it hard to get individual components (as opposed to a full system because I can use MS to control it). As far as I understand if you are injecting it as a gas it doesn't need any additional coding because the density doesn't change unlike LPG. I know there was a big thread on it, but that was for injecting LPG and didn't really cover gaseous injection. I guess this doesn't really help the original poster, but I'm definately on the hunt for info myself.
Grant
CNG NGV Natural Gas with MeqaSquirt
Well, I'll put my third cent in. I am about to try CNG injection on my VW diesel, and may try it on my Cosworth Vega. I am trying to understand how thier flows are rated.
Tony
Tony
Anthony R
75 Cosworth Vega turbo (MSII with EDIS)
91 Toyota Pickup, Auto(modified valve body), 22re 4cyl, 11:1 comp, cam, header, Fuel and VAST ignitor with o29y3
1968 Electric Subaru Sambar 360 VAN
'92 Biodiesel Jetta
'92 Biodiesel Jetta
I think part of the problem, is that once lpg is compressed to as little as 50 psi, it remains a liquid at ambient temperature. What I have found, is that the proper way is to inject it as a liquid, above 50 psi, this way, it is similar to gasoline, but without needing the additional enrichments(TPS based Asynchronous for acceleration) This way though, you actually need a fuel pump, or air pump to pressurize the system.
Anthony R
'92 Biodiesel Jetta
'92 Biodiesel Jetta
