MegaTune for MS1 Extra
Questions specific to Megatune. (Only about the tuning software, not about MS1/MS2 code or code features)
Note that Megatune is obsolete.
daxtojeiro
Post by daxtojeiro »
this is a link to an installer specifically for use with the latest MS-Extra code release (029t) it has the manual, the firmware and MegaTune options for Speed Density, Alpha, 400KPa, MAF, etc, so no messing with ini files, etc,
http://www.extraefi.co.uk/software/Mega ... taller.exe
Phil
http://www.msextra.com/manuals/MS_Extra ... _Index.htm for MS1 Extra Manuals
http://www.msextra.com/ms2extra/ for MS2-Extra Manuals
http://www.extraefi.co.uk/cobra/accobra.htm 5.0L TVR powered Cobra Replica (MSnS-E)
woh
Post by woh »
Phil,
Is this MegaTune 2.25 with the MSnS-Extra (029t) or a newer MegaTune?
daxtojeiro
Its MT 2.25 and 029t code,
Phil
m
Post by m »
daxtojeiro wrote:Its MT 2.25 and 029t code,
Phil
But I can´t find the 029t code in config. or am`I missing somthing??
m
daxtojeiro
the 029t code is installed with megatune, if you look in START - PROGRAM FILES - MEGASQUIRT the downloader will be in there and the code is installed in c:/programfiles/megasquirt/029t/
Phil
em_knaps
Post by em_knaps »
Cheers Phil,
This simplifies install onto laptops,
Ive updated my desktop with this aswell.
I had so many differnt extra codes and versions of MT
and they had started conficting with each other.
thanks again.
Daniel.
There is no spoon.....
tristanlee85
Post by tristanlee85 »
I was wondering if at all possible could there be an indicator of some sort they lets the user know if information is being burnt to the ECU and when it has completed. For instance, in the Constants page, when I burn the values, that screen seems to take a good while. I guess a user could just wait 10 seconds or so and assume that the information has been burt, but I figured if it was possible for a visual that'd be helpful.
I notice at the bottom of MegaTune there is a "SAVED" text box, but I'm not sure if that applies to a saved MSQ, log file, or saved values to the ECU.
1997 Turbo Saturn
MS3 v0.22
TunerStudio v[insert_current_version_here]
daxtojeiro
Hi there,
if MeagTune allows you control of the tabs then it has sent the info, i.e. whilst burning it doesnt allow anything to be changed, well thats the way I understand it anyhow :) MegaTunix has a RED area that shows you havent burnt the info and then BLACK when you have, may be give that a try it has some really cool new gismo's in it now too,
Phil
tristanlee85
Yeh I've noticed that in some areas whenever you burn code, everything is frozen until everything has been burnt completely. Under the constants page, you can burn everything and for me it takes about 15 seconds. While in the burning process, it lets me close out of the Constants page, but of course the gauges are still frozen until it's all been successful.
I just figured it might be a little helpful, even though there is a way to tell by the delay of tabs, etc. I think I will have to try out MegaTunix though. It's been a very long time since I've tried it and I'm sure it's improved greatly.
1997 Turbo Saturn
MS3 v0.22
daxtojeiro
tristanlee85 wrote:Yeh I've noticed that in some areas whenever you burn code, everything is frozen until everything has been burnt completely. Under the constants page, you can burn everything and for me it takes about 15 seconds. While in the burning process, it lets me close out of the Constants page, but of course the gauges are still frozen until it's all been successful.
Yeah, a lot has changed, even since I made this a lot has been added:
http://www.youtube.com/watch?v=CLlnJAyzIfQ
Phil
woh
Post by woh »
Wow :D :shock:
Great sound too. rumble rumble.....
Reverant
Post by Reverant »
Phil,
could you update the installer to the 029v code? Thanks,
Jim
[EDIT] My bad, the installer is updated, the first post isn't. :)
The man behind MS Labs
I-w
Post by I-w »
is there a beta version of megatune? 3.xx just wondeirng.
MS-1 3.0 ~ MapDaddy ~ Fan mod ~ Boost mod ~ 4G63 wiring issues Resolved!!! tuning Head Aches
bobtooke
Possible bug in Megatune installer
Post by bobtooke »
Phil,
I just tried to install the latest version of Megatune from this thread onto my new computer and my spyware programme (Pest Patrol) tells me that your installer file is corrupted with a spyware bug called "a-spy V2.12"
More info on the bug can be found here:
http://www.ca.com/securityadvisor/pest/ ... =453101425
Now, I'm not sure whether this is a valid alarm or not because Symantec Corporate Edition didn't pick it up but I thought I had better point it out in case we are compromising anyone's machine.
Regards,
Bob
Are you sure thats big enough to sit in?
MG Midget 1500 EFI 5 speed
Running MSExtra 029y4 on MS1 V2.2
Dark Helmet
Post by Dark Helmet »
is there any difference between this and the "regular" 2.25? I'm having trouble pulling the existing tune off of the ecu... "fetch" seems to not accomplish jack... VE table is all zeros, everything shows Zeros.
tristanlee85
The link is dead for me. Anyone else having troubles?
1997 Turbo Saturn
MS3 v0.22
I-w
Post by I-w »
is there a latest release for megatune MSNS-E or should i get it from the msefi site megatune?
speedy
Post by speedy »
Hi Phil,
The link to the 29t installer doesn't work anymore, can you pls send me a copy to :
koffeejava@yahoo.com
I had been using 29t eversince it was release, till my laptop crashed recently.
Thanks in advance.
speedy
tristanlee85
Re: MegaTune for MS1 Extra
Does anyone have a working link to this?
1997 Turbo Saturn
MS3 v0.22
woh
Post by woh »
