Hi there, and especially the MT developers,
I write a program to atomatically adjust the VE table after driving. The AutoTune feature is a cool thing of course but I think a table correction based on mean values of a whole datalog is more precisely.
With an old version of MT and Firmware and MAP-based VE table it was no problem, because MT, Logger and Firmware uses the same values for MAP.
But since I switched to TPS-based VE table I have problems analysing the datalog files because of the following reason:
I have no access to the raw value of the TPS signal. Since the VE table is RAW-value based and MT allways uses RAW data too, its necessary to get the RAW data out of the Datalog.
Would it be possible to get the value into the log-format without any pain? That would help so very much!
Thanks for reading,
Timo
Log-Value Suggestion
Running Suzuki GSXR 750 SRAD throttle bodies on Ford Zetec 16V
Using MegaTune2.25 and MS1 v2.2 with Spark'nExtra 029q, Knock system installed
If you look at the end of the msns-extra.ini file you can see what parameters are being logged and adjust as you wish.
