MT Displaying TPSADC not TPS% in VE Table when live...
MS1 - V2.2 - 029t - MT2.25
I'm having trouble getting MT to work in TP% in MegaTune when tuning Alpha-N.
I would prefer to have the TP column of the VE table to be in % (0-100), but when running live on the car, MT is always showing TPADC (0-234).
Has anyone else beaten this problem.
It's no big deal to use TPADC, but if I ever change my TPS I'll have to virtually retune my VE table.
Cheers
Rick
Cheers
Rick
-1988 325is BMW M52B28 - > MS2 Extra n Spark (60-2 Wheel, Wasted COP, Single VANOS)
-2004 Opel Corsa C / Holden Barina Z18XE - > MS1 Extra n Spark (60-2 Wheel, Wasted COP)
-1976 Triumph Dolomite Sprint Race Car -> MS1 n 'EDIS'd
-1984 C1 2.3 Alpina -> MS2 Extra n Spark (60-2 Wheel)
TPS% is only used in Megatune, the Megasquirt actually works in TPSADC. With MS1 there is no true "calibrate TPS". So even if you did work in %ages, it would still be a %age of TPSADC.
That's how I remember it - unless someone has figured out a better way for Megatune and MS1 to talk TPS.
Okie Dokie!
I'll train my brain to think in ADC...
Cheers!
Thanks for your prompt reply too!
Cheers!
I'm pretty sure you can get MT to display in % if you alter the msns-extra.ini file that lives in the Megasquirt/Car1/mtCfg folder on the computer. If you really want to go there, I'll try it on the bench first so I can head you in the right direction instead of a wild goose chase. I've been using tps ADC for 18 months and it's OK, and if you ever change the tps pot you can convert the tps ADC values in the VE table from the old one to the new one with a calculator and a 6-pack (presuming they are of the same linearity). The beauty of running tps ADC is that what you see in MT is exactly what the MS is seeing, so if any errors due to drift or wiring faults arise you will see it very quickly. With alpha-n it is critical that the tps works flawlessly.
Ian.
Ian.
Sounds great!
I'll wait for your next post....
theres a load on Alpha_N in the manuals here:
http://www.msextra.com/manuals/MS_Extra ... htm#alphan
could be of some use to you, it also tells you about it being in ADC, etc,
Phil
Phil
http://www.msextra.com/manuals/MS_Extra ... _Index.htm for MS1 Extra Manuals
http://www.msextra.com/ms2extra/ for MS2-Extra Manuals
http://www.extraefi.co.uk/cobra/accobra.htm 5.0L TVR powered Cobra Replica (MSnS-E)
I'm sure it used to be a lot easier a couple of years ago, so maybe this is not the easy way to do it, but it appears to work. Go into C/program files/Megasquirt/Car 1 or whatever your project is named/mtCfg and open up the msns-extra.ini file with notepad or whatever. Do a control + F to find "outputchannels" and change the line
tpsADC = scalar, U08, 7, 1.000, 0.000
to tpsADC = scalar, U08, 7, scale, translate
where scale = 100/(WOT tps ADC - idle tps ADC), and translate = - idle tps ADC
This makes MT display the tps in percent even if the gauge says ADC.
Then to get the VE table to display in tps percent about 3 pages down from the top is a line
#elif tpsBins1 = array, U08, 170, [12], "TPS", scale, translate, 0.000, 255.0, 0.
Drop in the scale and translate numbers from above, and change 255.0 to 100.0
Ian.
Ian.
It used to be easier on the face of it, however it was actually incorrect and the Megatune displayed TPS% didn't match the value used in the VE table. The method you propose should work as long as you adjust the .ini file anytime you re-calibrate your TPS.
So what's the consensus?
Does newtyres1's idea seem like the way to go, or stick with ADC?
I think i'll stick with ADC to avoid any screw-ups...
Thanks for your help though!
It looked good on the bench with stim, but as James pointed out the downside is that if your tps WOT and idle signals ever change then you'll have to update the ini file to make MT display properly again. If you're worried about messing up the ini file, then save a copy of it first, so you can restore the original file later if required. There is a risk factor involved so if you're not the adventurous type then best to stick with ADC.
Ian.
Ian.
